Question about GE Energy Star WCVH6260F Front Load Washer
Cleaned Out Pump
Yes, I pulled the pump and did not notice anything clogged. The impellar is somewhat free, but I noticed the after trying to run the machine the motor is super hot. You can't touch the housing. I took it off and it stayed hot for nearly an hour or so. I went ahead and ordered it. No one locally has it or has ever ordered one. I contacted 3 or 4 appliance parts center. I am hoping that the washer doesn't cycle properly, because there is some sort of water level sensor sending signal that washer has water. I drained the water and still can get it to cycle. Expensive experiment $137.00 for pump. I noticed many people seem to have the same problem with this machine. My wife wanted a front loader, didn't want to spend the big bucks so I bought used from a couple moving. She will never let me here the end of it, until I get this fixed.
  • Jason McKeehan
    Jason McKeehan Jun 03, 2008
    Recieved the pump today.. Installed and everything works great. I will definately keep a eye on the clean out... GE needs to send all the customers a cover plate that doesn't hide the clean-out. I don't plan to put my plate back on. It is ugly, but I won't burn up another pump....
Sweet tip, goingbamboo - exact same motor, different housing, only $60 shipped by fedex ground from repairclinic.com.
so i had the exact same problem. two newborn socks, one which appeared (smelled) like it was there for quite some time, 3 quarters, and some odd lint. for the life of me i can't figure out how the socks get from the drum down the tube!
word of warning - if there is visible water in the drum, there can be a *lot* of water when you unscrew the filter cap.
oh, and we have also been noticing rips in our clothes (like another poster). worthless machine.
Posted on Jun 20, 2008
If you should run into problems again with that pump, there is a way around the $137.00 replacement cost. You can order the pump for one of the top loader machines (here is a part # WH23X10013). They use the same motor. There are 3 screws to remove the motor. The top loader setup is considerably less expensive. And if you trust ebay, you can get the motor for $45 shipped to your door in about 3 days.
For mine, the issue was one of my son’s newborn socks made its way into the drain and clogged the filter. I have had this machine 2 years and love it. This is the first problem we have had.
Posted on Jun 13, 2008
Will it hurt anything if I use an air-compressor to blow through the washer tubing on my 2006 Jaguar xj8?
I would not use anything more than say 10psi of pressure. I doubt using air pressure will fix the clog if that is the problem, because the pump uses 10-20 psi in normal use. You may have to disconnect the nozzles and use a pin to clean out the ports or find the clog in the main line.
Jun 04, 2014 | 2006 Jaguar XJ8
Lg wm2455h is not draining: i have taken out and cleaned pump filter and that did not correct the problem. I place the machine on the drain and spin cycle and i can hear the pump hum, but doesnt drain. ...
most likely you have a bad pump and it needs to be changed out or something is still stuck in the impellar,stick your finger into the pump and feel around the impellar,i've found under bra metal pieces stuck in there,elastics and string rapped around it and coins lodged in between the impellar and wall of the pump,if the pump is bad or something is stopping the impellar from spinning it will hum,power is going to the pump but the motor isn't spinning.
Nov 12, 2011 | Washing Machines
Hello all I have been getting the F21 error code (seems to be a popular error) I cleand the drain on the pump as I was cleaning debris out i noticed the motor impellar was cracked so I replaced it. ...
My WAG would be yes, something is still in the drain line. Especially since enough debris has been through it to crack your impellar.
Have you tried running a guitar string up to see if you can dislodge any blocks.
Jun 09, 2011 | Kenmore Washing Machines
1989 F-150 stalls going uphill
you will need check with a ford dealer
there are a number of recalls and TSB's for the trucks with dual tanks.
and if a recall applies to you its free
Oct 22, 2009 | 1989 Ford F 150
F02 light flashing during every rinse
If you have noticed water isnt draining, that almost certainly will be the problem. Depending where in the program the problem starts so will the different error codes appear. Remove pump and clean the contents at the impellar., then retry.
Sep 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My bosch classixx dishwasher won't drain
It doesnt take much to stop a drain motor from rotating. If you dont know the bosch washer, you will find it almost impossible to get into it One thing, if the door is opened, the bottom tray removed then the sieves untill no loose items are left, you will notice a little piece of plastic that can be pulled out to allow you access to your drain pump impellar. Remove the obstruction and turn with your finger. Does it turn easily.? if so reassemble and try again.(note if you dont replace the plastic part back properly, the pump will run but not pump correctly.)
Sep 24, 2009 | Bosch Dishwashers
Kenmore Elite HE4T not spinning and draining
The only way to access the imperller is remove the coin tray (unscrews and pulls out) and the hole into the pump on the right side will have the impeller right there..The pump itself shouldn't be taken apart. It may not seal up correctly.
Mar 13, 2009 | Kenmore Elite 45986 Front Load Washer
Drain pump
You may have a problem with the pump vane not properly spinning on the drain pump shaft.  If you take out the drain pump and spin the vane in either direction, you should feel a resistance every time you turn it.  If you able to turn the vane one way and do not feel the resistance for at least half a turn, you may need to replace the drain pump.
May 03, 2008 | LG WM1812C Front Load Washer
How to clean pump
If you can turn the impellar on the pump with your hand and it runs freely, then the pump is ok. You should maybe look at the hose that leads to the drain pump from the drum, or the drain hose that goes from the pump to the sink/tub. It may be clogged with lint. Remove the drain hose from the spigot under the sink/tub and check the spigot. It too may be clogged. It is not possible to get into the pump. It is a sealed unit, unless you are able to unscrew the impellar from the motor shaft to check underneath it.
Oct 12, 2007 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
133 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
