Question about Late for The Sky Bibleopoly Monopoly Style Board Game
ELISHA CAST HIS MANTLE UPON WHO - Late for The Sky Bibleopoly Monopoly Style Board Game
  • 490 Answers
Elisha
Posted on Oct 11, 2010
Hi, I have a home work question, what does lithosphere? thanks :)
That is is the solid outer section of Earth, including the crust or rock layer on the outer layer of the planet, the oceans, and the upper solid part of the mantle. Next down is the lower mantle and the core.
https://en.wikipedia.org/wiki/Lithosphere
Apr 15, 2016 | Optics
How can I lubricate a vintage table saw?
Hi Donna:
I recently cleaned up a 40 year old craftsman that had been siiting outside for about 2 years. The cast steel parts were really badly rusted but it cleaned up with sandpaper and oil and a lot of solvent.
The motor was belt drive to the blade, and the bearings on both freed up with soaking and flushing with solvent, then packing with white grease. If the bearings eventually fail I'll dis-mantle the parts and replace them.
Hope this helps.
Feb 04, 2016 | Saws
What does plate tectonic theory mean
Plate tectonics is the theory that Earth's outer shell is divided into several plates that glide over the mantle, the rocky inner layer above the core. The plates act like a hard and rigid shell compared to Earth's mantle.
Feb 20, 2015 | Edu-Science (10166) Telescope
Feeds paper stops tray
Hi Elisha,
it is very hard work.
please go to authorized repair center.
regards,nuwan
Jan 10, 2014 | HP Photosmart C3135 All-In-One InkJet...
I just bought a 46 inch SAMSUNG LED HD TV from Best Buy and will be mounting it on a brick wall above the fireplace. The fireplace has gas logs with a an 8 inch mantle that extends 8 inches off the...
it is not safe to mount the TV 8 inches above the mantle.
Secondly, the heat will certainly be a danger if the TV is mounted above the mantle.
I would advice you look for another position to mount the TV.
I hope the above is clear.
Regards.
Sep 27, 2011 | Televison & Video
We have a French farmhouse which is 170 years old. Broken Mantle.
If your mantle is stone I would suggest drilling 2-3 holes diameter should be relevent to the thickness so as not to split the stone. do this on both sidees of the mantle. Use a branded epoxy such as araldite and bond steel rods into the holes in the stone mantle bridging them together, any fine cracks can be filled with a fire cement and wiped clean.
Hope this helps
PB
Nov 14, 2009 | Crafts & Hobbies
I want to mount my 42" LCD TV above the fireplace mantle. Will the heat from the fireplace damage the TV. How far should it be recessed?
it's not a good idea to mount any tv above a fireplace mantle. Anytype of excessive heat added to the tv besides what it generates itself can cause distortion and loss of use in the tv by saudering or melting of connections that you cant see. If in doubt, is there a place where youve seen a tv mounted above the fireplace mantle, and ask them about any issues they may have come across, or are they also restricted to keeping the fire very low.
Aug 24, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Wick trouble
yes,
the wick is held onto the moving mantle with pointed pins protruding from mantle. remove the mantle assembly and remove wick. then, if wick looks charred black on top, clean top of wick by trimming evenly all around with very sharp scissors; otherwise, use stiff brush... then assemble wick to a location that will be about 1/4 to 1/2 inch higher than when removed. may as well flush out kero tank before final assembly.
Jan 24, 2008 | Corona 23-DK Compact Heater
Late for The Sky Bibleopoly Monopoly Style Board Game Logo
79 people viewed this question
Top Late for The Sky Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Late for The Sky Toy Expert? Answer questions, earn points and help others
