Question about Canon PowerShot S3 IS Digital Camera
S3 is issue
Every time i put in freshly charged (new) batteries, i take a couple of pictures then the camera tells me to change the batteries>???? any ideas??
  • goonan May 31, 2008
    camera turns on shows error 18 then shuts down
    Novelist:
  • 130 Answers
E18 is a lens error that needs to be serviced by Canon technicians. You may qualify to replace your S3 for a flat rate or to repair, but it is nothing that you can fix at home.
As for the batteries, what brand? If they are rechargable, make sure they haven't been drained-try them in another device perhaps. I drained mine by leaving them on the charger too long and I had the same issue. Try another set of batteries and clean the battery contacts inside the camera with a pencil eraser to get rid of any residue or oxidation that may have taken place.
If none of this helps, call Canon for service or other option to upgrade for a deep discounted rate. Sometimes it's cheaper than to fix it if you are out of your one year manufacturer's warranty.
Hope this helps!
Posted on Jun 01, 2008
I have a problem with my Canon S31s - Each time I power up I am getting a 'Change Battery' warning and camera shuts down. I have tried 2 sets of Duracell and same prob keeps happening. The terminals are...
Why not try a set of rechargeable batteries? they can be used 5 times as long as alkaline batteries, every time you charge them. And when you have charged them yourself you can be sure they doe have the capacity needed for the camera. There is no way of telling alkaline batteries are full, because even when they are exhausted they will give the same voltage on your multimeter as a new battery.
I don't think it has to do with the date battery, because that would show you the date / time menu on the display.
Oct 28, 2013 | Canon PowerShot S3 IS Digital Camera
CAMERA WON'T LET US TAKE A PICTURE
Make sure you are using either NiMH rechargabeles or quality name brand alkalines to get rid of the change battery message. As for the balck screen, it is likely that the shutter is jammed closed and the camera needs to be cleaned / serviced.
Jun 09, 2010 | Canon PowerShot S3 IS Digital Camera
Camera says replace batteries even when fresh ones are installed
Sir/Maam,
Have you tried using new batteries? How long have you been using the old batteries? As far as i know, the longer you use a rechargeable batteries, the shorter its life(compared to the first time you used it).
Try using new batteries, if the problem is still there, the camera my have the problem. But if the camera works fine, then your old battery is defective.
Keep me update, hope i helped you. Thanks.
Feb 27, 2010 | Canon PowerShot S3 IS Digital Camera
Shooting mode shows nothing.
I just had this issue with my camera (my 15 year old son solved it for me ;-) ).
The viewfinder was active in "record" mode and the LCD was "active" because you could see a little back light but no image. The "playback" mode would let me review pictures in the LCD though so I know it is capable of showing information.
If you push the display key/button a couple of times you can see the picture move from the viewfinder to the LCD and have just a picture and or a picture and information.
So try setting the camera to "record" mode (lens comes out) and then push the "display button" which is on the back of the camera just to the right of the LCD on the lower right side several times and see if the LCD starts to work.
It could be that somehow the display button was pushed by mistake.
Bill
Dec 07, 2008 | Canon PowerShot S3 IS Digital Camera
Last year I bought my mom a digital camera for christmas. It worked great for about 2-3 months. Since then it is speratic, it will turn on let you take a couple of pictures then shuts down all by itsels....
Hi! Most digital cameras require outrageous amounts of power to work properly. Be sure to use only high quality, hi power ni-mh rechargeable batteries. Check for Sanyo Eneloop or Duracell. Sometimes we think the camera is broken, but in most cases is only insufficient amout of power. If you can't find the before mentioned batteries, look for 2500mA NI-MH type rechargeable batteries and a proper charger. Good luck!
Nov 22, 2008 | HP Cameras
Canon S3 IS: no picture on display
Call Canon for free tech support and I'd advise sending it in for free estimate. If your camera is more than a year old, you will qualify for the upgrade program which is often cheaper than repairing it.
Hope this helps!
Mar 29, 2008 | Canon PowerShot S3 IS Digital Camera
Digital Camera
Unfortunately this camera is very bad for battery life because the zoom lens itself takes up alot of power. I would have the same problem with putting fresh batteries in and they would only last a couple of minutes.
I went to Blacks and asked their opinion and they suggested a Lithium Ion battery which came with the charger.
The charge only takes 30 minutes and I have been using my camera all week and the batteries are still going strong!
The price for the pack and charger together was a about $29 and it was totally worth the money
Jan 20, 2008 | Canon PowerShot S3 IS Digital Camera
Canon A95 "Change Batteries" problem!
I have this problem as well. I thought it was a problem with my NiMH batteries. So, I bought a volt meter to make sure the batteries worked. I have 8 AA NiMH batteries. I charged them all up and tested them with the volt meter. They were all good to go. However, no matter what I put in the camera one of two things happens:
1. I get the "change batteries" message.
2. I don't get the message, but the next time I check the camera (a few days later), one of them is totally drained.
Something is very wrong and I plan on contacting Canon.
Nov 30, 2007 | Canon PowerShot A520 Digital Camera
Suddenly the batteries have started dying after 2-3 photos
did you try using lithim recharge battery i my self had the same problem with 1sd pentax ithout my camera was naced
Mar 25, 2007 | Olympus Camedia D-580 / C-460 Digital...
Canon PowerShot S3 IS Digital Camera Logo
110 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
