Question about Microwave Ovens
I have the problem of my galanz microwave "beeping" turning off and on automatically.???
  • 4 more comments
  • jgb64150 Oct 14, 2010
    I was not satisfied with previous solution again, are there any buttons to push that might cause the microve to operate properly?
    I tried your solution....I am still getting beeping sounds>
    are there any combinations of buttons to push that enables my galanz microwave to operate properly? it is "didital"
    not helpful thanks.
    yes..
Try holding down the stop/reset button until it beeps. If this does not stop it from turning on/off automatically then you may have a loose connection in the wiring between the inverter, magnetron, and/or control board, or one of those components have failed. Because of the lethal voltages used and produced with inverters, I do not recommend that an inexperienced person repair it.
Posted on Oct 14, 2010
    Genius:
  • 1,478 Answers
I will advice you reset your microwave oven, follow this steps to reset it, Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display, for example, and the "Your Food is Ready" message will disappear. or
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Take care.
  • 11,896 Answers
First thing would be to check the power cord. Make sure the prongs are tight inside the outlet. Next would be to remove the outter shell of the microwave while it is unplugged. Check the plugin to the power converter. See if the wires are securely attached. Check that the fuse is attached and secured and that it doesn't look burnt. If so, replace it.
Check the main circuit board as well as the control panel to make sure there are no leaking capacitors or any burn marks on the circuit board. This would indicate a faulty capacitor that may be burnt or leaking.
Posted on Oct 11, 2010
  • Nate Stansfield
    Nate Stansfield Oct 14, 2010
    try unplugging it for for 1 minute. While unplugged, press and hold the stop or cancel button for 10 full seconds. Then try plugging it back in and see if it reets. You could very well have a stuck keypad which would surely cause this.
How can I silence the BEEP?
If your owner's manual doesn't mention such a feature, there are alternatives.
https://youtu.be/ITHDE-vFaiw
Oct 07, 2016 | Galanz Microwave Oven-Import 7Cuft Wht...
When I ask for a Galanz microwave oven manual you send me anywhere except to the manual. WHY?
To download information on Galanz products go to this site:
http://www.galanz.com/Download.aspx?ColId=110&SecId=117
The Magic Chef site for microwave ovens is here:
http://mcappliance.com/microwaveovendetail.aspx
Unfortunately I did not see the model number you provided listed here. However they do provide manuals for their products and if you select a model that is similar to yours you might find the available manual to be useful.
Feb 02, 2011 | Magic Chef MCM1290A Microwave Oven
Code 310 galanz microwave
code 310 in galanz microwave
Jan 22, 2011 | Microwave Ovens
It is not heating up feels like it is in child
Try holding the RESET button in until it doesn't say LOCK anymore, did this by trying to solve another issue I;m having with beeps and 310 code??
Feb 07, 2010 | Microwave Ovens
NO All i need is an English manual for a Galanz
You might have a little trouble with this one. But all I can suggest is sending an email
to them and ask for the manual. They should have a pdf version online but I don't read
any Chinese so can give you that directly. Most household goods companies tend to
respond within a few days about manuals.
E-mail: info@galanz.com.cn
English website: http://www.galanz.com
Jul 18, 2009 | Microwave Ovens
Galanz (french for ''****'') microwave is sporadically beeping
maybe, just maybe, there is an error code showing....and, most microwaves beep when a button is pushed too...LIVE WITH IT!
Jul 06, 2009 | Microwave Ovens
Where to purchase a new fuse for Galanz Microwave
20A ceramic fuses can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Feb 13, 2009 | Welbilt MR755T Microwave Oven
Galanz Microwave Oven - Unable to disable child lock
Galanz's website seems to be useless. I tried finding information but kept being told "no data available." So while I can't tell you where to find the manual, here's something to try. Most microwaves get put into lock by pressing and holding one of the buttons for longer than normal, or by pressing one of the buttons several times in a row. Some ovens use the TIMER button. It won't be one of the number keys, but one of the function buttons. So start with a button, press and hold it for at least 5 seconds before you let go. If nothing happens then try another button. If that doesn't solve the problem, then try pressing each function key several times before moving on to the next one. If that still doesn't get it going, maybe a store in your area that sells Galanz will take a look at the book for you. The process should be the same for any similar model.
Nov 11, 2008 | Microwave Ovens
Microwave Ovens Logo
596 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
