Question about Quickie Wheelchairs Quickie Wheelchair 18" Black Back Upholstry Tall Tl
Wouldn't run, blcking 2 light - Quickie Wheelchairs Quickie Wheelchair 18" Black Back Upholstry Tall Tl
  • 692 Answers
Joe you don't give much info but 2 lights indicates left motor disconnected. Check the cable to the motor to make sure it didn't come loose from the controller Hope this helps
Posted on Oct 12, 2010
2000 Pontiac Grand Am SE security system wont let car start
first most GM OEM systems will need to recognize the key first and foremost ,to do that you will need to roll window down on driver door,turn the key to the run position and with engine NOT running leave the key on for 10 minutes exactly ..then turn ignition off then try to start engine. if original system is working engine should start normally
Mar 26, 2017 | Cars & Trucks
Electrical problem on 1996 Dodge Dakota
It will drain at a rate of 21Watts X 2 = 42Watts at 12Volts = 3.5Amps. If you have an 70 Ah battery that is 20hours to totally flat from fully charged.
May 27, 2017 | 1996 Dodge Dakota
Healthrider 500i. The screen lights up with no belt, fan, or key pad response. I manually started the belt then it wouldn't stop or change speed.
adjust the Reed Swith see the diagram:RESET, clean, and tight cable connector.
2) Run the software calibration for easy diagnostic, troubleshooting, and fix it.
God bless you
Aug 28, 2012 | HEALTHRIDER Pro H500i Exercise Workout...
Poulan 3600 Timbermaster. Saw hasbeen unused for over a year. I got it to start with starting fluid. Wouldn't stay running or accelerate. I used carb cleaner with engine not running. Now it has too...
Hello; Dump out all the gas in the tank and put in fresh gas with the additive called "Stabil" it is a red liquid you can but at Walmart or any auto parts store. The trick will be to keep it running long enough for the Stabil to degunk the carb. I also had a weedeater that wouldn't stay running and replacing the plug solved the problem, so also try a new plug. They are only 2 bucks! John
Sep 18, 2011 | Poulan Garden
I can not use my limewire it says that a firewall might be blcking limewire
U Just disable a firewall in ur system or disable antivirus protection if needed
Jan 28, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Quickie Wheelchairs Quickie Wheelchair 18" Black Back Upholstry Tall Tl Logo
50 people viewed this question
Top Quickie Wheelchairs Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Quickie Wheelchairs Health and Beauty Expert? Answer questions, earn points and help others
