Question about Amana ALG331RAW Gas Dryer
Amana Dryer ALG443RAW little heat. It heated slightly and know there is no heat. It is also very noisy when drum is turning.
  • Amana Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Mar 04, 2011
On amana dryer gas the knob at the end lights all around but goes off it doesnt stay lit
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 23, 2011 | Amana ALG443RAW Gas Dryer
Amana ALG443raw gas dryer
sounds like the thermostat is shot..do you fix this sort of thing yourself?
Mar 17, 2008 | Amana ALG443RAW Gas Dryer
The dryer heats, motor runs but drum doesnt turn.
Could be one of several things. The drum turns by motor and fan belt around the drum. The most common problem is that the fan belt is broken. Check to see that the drum is free and not bound up by frozen bearings. Also that nothing is jamming the drum. If everything seems to be ok --- you need to check the pulley on the motor shaft and be sure it is tight on the shaft . More than likely -- it is a broken belt. I hope this helped.
Dec 14, 2010 | Amana ALG443RAW Gas Dryer
I turn on my drier and the coil heats up the gas comes on only sometimes then the gas shuts off shortly afterwards. Then i try to restart it the coil turns red with no gas.
The dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video at this will walk you thru troubleshooting a gas dryer.
Sep 22, 2010 | Amana ALG443RAW Gas Dryer
Amana dryer makes rumbling noise when the drum turns
heatman101
fsdjds
Nov 16, 2009 | Amana ALG443RAW Gas Dryer
Amana ALG443RAW Gas Dryer will not heat up.
you can remove the lower acess panel (2) 5/16 screws along bottom. youll get a good view of workings there. turn on dryer (make sure a heat cycle is selected. you should see the ignitor light with in a few secs. if not unplug the ignitor(small white connector maybe 6inhes back from ignitor itself) and with a meter ck for 110v in that connection when unit is turned on, if you do have 110volts , you hav abad ignitor. ifyou dont get 110 volts you need to check the thermostat(s) located on top of the heater box right above the ignitor, if no continuity you need a new thermo.
Mar 12, 2008 | Dryers
Dryer problems
power transformer on it went or main bord controler i would call guy in pin point it instead of us having u chnage this and that
Feb 03, 2008 | Amana ALG443RAW Gas Dryer
Amana ALE643RAW Gas Dryer
.hi with gas dryers the parts to look for are . the blower . will take longer to dry and noisy .The venting very important. The coils on the gas valve .Will cause the flame to only come on for a few minutes . then nothing so for that problem . replace the coils. Thanks the appliance doc
Dec 05, 2007 | Amana ALG443RAW Gas Dryer
Amana ALG331RAW Gas Dryer Logo
91 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
