Question about Bausch and Lomb Bausch&Lomb Spotting Scopes - Elite
I have had this scope for about 15 years and have always been happy,However I am going on a hunt soon so I went shooting. I could not even hit paper. So I went home bore sighted it went out again & was about way off maybe 2' right & 1' low.So I tryed bore sighting it again way high to the right. Mved to 25 yards from 100 on the paper about 3" right moved to 100 yards off the paper.So then I was out of bullets.What next I am worried about the scope. Dan
  • danielcrombi Oct 14, 2010
    I was looking for some insight on how to check out the scope.I have been shooting for about 40 years and have not had this type of problem before. I suspect a problem with the scope but can't see anything wrong other than my inability to zero it in this year.
  • 12,061 Answers
Were your mounts tight? I have had this happen to cause this to happen? By Mounts I mean ALL the mounts, every screw.... Also I have had a Reticle go awry INSIDE a scope and every time you shot, it changed its point of shot.
What I used to do, was Bore sight it with a little $2 laser pointer.. for about 25 yards, put the spot on the card and wind my cross-hair reticle onto the spot... Now it simply MUST be "On" well to at least 25 yards, then i go to the range and let one fly at 50 yards and adjust the reticle again moving the reticle to the bullet's impact point. Try a group of 3 - 5, getting it perfect and then move out to 100 yards, doing the all the same things.
Usually I make the gun shoot about 1" to 11/2" ABOVE the Cross Hairs, at 100 yards, this then, well with a lot of guns puts it dead on again at about 300 to 350 yards. and if you can reach out an tag to 400 - 500 yards it will be an inch or so LOWER than the aiming point, I have always found this pretty satisfactory for all my hunting conditions, from 25 yards right out to 500 yards, Oh, I always like to have all my shots at least within one minute of an angle, at 100 yards...But don't be too fanatical as remember most times usually you have a 30 - 30" Chest target, and generally anything in the "Boiler room" will give you your trophy or a feed. Now if you like head shots.. well thats another story.
Posted on Oct 15, 2010
  • 3,083 Answers
I read a pretty good blog about sighting scopes, but it looks like you've gone through all the steps except for maybe the final shooting at 100 yds. Here's the blog, and he suggests a couple steps maybe you haven't tried:
http://www.alpharubicon.com/leo/zeroscope.htm
It sounds like the scope may have gotten dropped or slightly out of adjustment somehow- you might try running it by a gun shop and seeing what they think, or if they've seen this problem before, and know how to adjust/fix it.
It sounds like you're getting there, but need to fine tune possibly, after you get a few more bullets to try.
Good luck, and hope this helps.
Posted on Oct 12, 2010
What is a hunting scope
See http://www.leupold.com/hunting-shooting/scopes/
Oct 20, 2014 | Optics
How do you sight in a redfield scope
Your scope should be "in the ball-park" out of the box. This ball park will of course be determined by the height of scope rings you put on your rifle. The taller the scope rings/bases the lower your initial shot... Go to a range or safe outdoor shooting area. Put a large target up at 100 yards, 16"x6" will usually do. Aim at the bulls eye, and click off a round. Use a spotting scope, binoc's or your scope to see where your shot has hit. If it is off the paper and no where to be seen, click off a shot one foot high, check paper, repeat one foot low, one left, one right until you find your shot on paper. Once you find your shot, you will need to adjust the windage (left to right) or elevation (up to down) by using the turrets on the scope. Part of the trick in sighting in your scope is to remember if your shot is high, then you need to crank the turrets in the "up" postion (if it shoots left, turn turrets to the left, and so on). This part is sort of counterintuitive, and may feel foreign. Once you get your scope on paper, continue to adjust until you are hitting consistently 1 inch above bulls at 100 yards. Shooters benches and rifle rests help in this process, but it can also be achieved without. I hope this helps. D
Jul 26, 2014 | Redfield Optics
How do you make adjustments, towards the shot or towards center of the target?
You move the cross hairs to the shot. Set up your gun on a bench and start by firing at a target out at about 15 yards. Once you are "on paper" set your cross hairs on the center and fire a 3 shot group Adjust the scope to the group. if the group is down 3 inch and left 4 inch. Adjust your scope accordingly. Then Fire another 3 shot group, until you are shooting center. Every time you adjust your scope tap the barrel of the scope with a screwdriver handle to keep the cross hairs from sticking. Once on at 15 yards move out to your max range and adjust to that.
Mar 19, 2011 | Brunton 2x20mm NRA Sports Optics Rifle...
Leupold VX II 3x9x50mm scope on a rem. 270. One year old. Worked fine last year. Sighted in last week at range. Windage was dead on. Wanted to move up 1 inch in hieght at 25 yards. Tried to adjust hieght...
16 clicks is about 4" at 100 yards not 25. did you try shooting it at 100 yards? remember the scope is mounted at least an inch and probably higher than that above the barrel. at close range you will always hit low with a scope because the bullet has to climb at least an inch or more before it will be right on at 25 yards. if it is dead on at 25 it should hit way high at 100. (or the scope/ mounts are bad).
Nov 05, 2010 | Leupold ® Rifleman® 3-9x50 mm Scope
I have a barska 6.5-20 x 50 scope and it is mounted on a 243. I have killed several animals with it and the other day my mounts got loose so I tightened them up evenly and now my scope shoots low and will...
it could be that the mounts are still not in the right place on the rail it would be the eye end thats out,,,try taking the mounts off and cleaning them then re-fitting them this may help but i think
when the mounts become loos the recoial from the gun firing could have shook loos the scope inners or even bent the mounts,,,if you can try a new set of mounts first,, but i bet the scope has now gone to the happy hunting ground in the sky
a 243 has a *** of a kick on it!
Aug 11, 2010 | Barska Optics Barska® 6.5-20 x 50 mm Rifle...
CAN NOT ZERO GUN
You may try to bore sight it first. Pull the bolt and setting the gun on a good rest sight thru the barrel at a dot on the wall within ten feet. Then adjust the scope to that dot. As you adjust the scope tap the bore of the scope with a screw driver handle, tap it after each adjustment not hard, but enough to give it a sharp jolt. Once you are close here, move out to the range and shoot at 15 yards. Using a rest, again tap the scope after each adjustment. Then move out to 50 yards and you will want to be shooting high 1.5 to 2 inches here. Shoot slow keep the barrel cool and try for 2 shot groups till you have got the scope dialed in. Then move out to 100 yards for your preference of zero. Remember use the same ammo you will hunt with or at least the same bullet weight. If you can't get her to get on paper you can try to loosen the scope in the rings, one at the time once the gun is a little warm. Loosen the barrel ring first then snug it back down and then the receiver ring. If your group moved now, she was in a bind due to a cold gun at set up / installation.
Dec 01, 2009 | Optics
Umm ok im new to sighting scopes i usally dont use scops for deer hunting but this year i am shooting up to around 100-450 yards...well i can sight one in but how do i shoot at a deer at farther ranges...
Learn your round, the key to long shots are in the bullets you chose. How much drop out to 400 yards. Shooting a 22 LR at 100 yards will teach you how to factor in for bullet drop. Most 22's will drop 6-8 inches out at 100 yards, then you have to deal with the wind, pratice with a good 22. Now on to your scope, if you have say, a 30-06 sight it in at 4x dead on to 125 yards. you will be high at 60 - 75 yards and low at 200 yards. Sight it dead on at 150 you will shoot high at 100 yards. so on so no. Best is dead on at 150., w/4x. Leave it a 4 power till you need more. Now turning up the power will move the point of impact a bit you have to learn how much by doing (pratice), shoot out there to see what she does, and then you know. Then you have to deal with a cold gun, she will shoot different cold. The key to a good clean kill is to know your gun and how she shoots, where, when, cold, hot, wet, dry. Low light, bright light even will make a difference how you see the cross hairs where on the target. Next, your cross hairs have a built in range finder, they have a wide line that tapers down to fine, this is a good way to tell how far away something is get a paper plate and paint it red. put it out at 100 yards that is a good kill zone for a good sized deer. Look at the plate through the scope and judge your spot for 100 yards. 4x, 6x, 9x. you then can guess your distance to deer by looking at the cross hairs step down. Deer chest is ruff the same size as the plate. Good hunting, I want to see a picture of all you take this year.
Oct 20, 2009 | Bushnell Banner 3-9x40 Riffle Scope, Matte...
Simmons scope that will not stay on target
Mount the rifle with the scope and make a mark on the backstop right where the crosshairs are pointed at
Shoot several times, several shots will surley jolt the scope some.
If the crosshairs have moved much past your mark then this would indicate the scope is the issue.
If the crosshairs are still pretty well centered to the mark, its not the scope.
If at the same time your grouping looks terrible, and your scope still is on the mark, and the gun is WELL mounted, then the issue is with the accuracy of the rifle.
Make sure the rifle is mounted good for this to ba accurate .
Hope this helps
Feb 06, 2009 | Dual Electronics 6-24x50 AOE DUAL...
Scope
Follow these steps
1) Mount your scope.
2) Use a bean bag or rifle mount and make sure that your rifle doesnt move much from its original position throughout this process.
3) Aim with the scope and shoot at a large backstop which will allow you to see where your shot lands, where ever that may be, it doesnt matter at this point. Again, make sure your rifle doesnt move much when firing.
4) With the rifle in the same position, look through the scope and adjust the crosshairs over to where your shot landed.
5) The scope now sighted in with the rifle. Minimal adjustment may still be required but at least your well within the ball park.
Happy Shooting
Nov 13, 2007 | Bushnell Trophy Multi-Reticle Red Dot...
Optics Logo
37 people viewed this question
Top Bausch and Lomb Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Piyal Perera
Piyal Perera
Andrew Taylor
Andrew Taylor
Are you a Bausch and Lomb Optic Expert? Answer questions, earn points and help others
