Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Hand wheel turns hard - Singer CE-200 Quantum Futura Computerized Sewing Machine
Hand piece is very tight to turn and unable to use the machine
Make sure to clean/remove all the lint, thread, dust, etc. that may have built up in the bobbin area, around the feed dogs, and under the needle plate. Sometimes gunk build-up will prevent the hand wheel from turning. Remove the bobbin & bobbin case from the machine and the needle and see if the hand wheel will turn. If not, then it may be time for service.
My hand wheel is hard to move and will not make complete turn unless...
https://answers.yahoo.com/question/index?qid=20100518074139AAeeykz
Help My Needle Hand Wheel are Stuck Sewing Machine Jammed
Apr 20, 2016 | Sewing Machines
Needle with not go up or down without a grinding noise and hand wheel won't turn. Help!!!
If the hand wheel turns hard or won't turn manually take it in to a repair shop.
Jun 10, 2015 | Sewing Machines
How do I add thread to the bobbin
The small box you will turn towards you while you hold the big handwheel. It might me very tight but it isn't going to break by turning hard. Tighten the small screw before you begin. When it is loose you can wind your bobbin.
Feb 23, 2015 | Sewing Machines
The hand wheel is stuck and won't move. machine makes a vibration noise
try working it back and forth it might jst be stuck a little but vibrating might mean you are putting it out of time too.
Jan 19, 2015 | Brother XR9000 Sewing Machine
Hand wheel is hard to turn
even though the machine is fairly new, it sounds like it needs to be serviced, to see if there are any broken or damaged parts.
Jan 24, 2014 | Singer Sewing Machines
Blocked motor message for 2140. Has happened 3 different times. Sewing machine repair is two hours away and I need my machine today. I did all the thread things suggested with the bobbin, re threading,...
You said the hand wheel barely moves. Is that all the time? If the hand wheel is hard to turn the motor is getting overloaded and is protecting itself by stopping and giving you the error message. You need to determine why the hand wheel is tight. There could be thread caught or something might need lube. These are non oiling needed machines however sometimes a linkage might need fresh lube.
Sep 12, 2013 | PfaFF Sewing Machines
HAND WHEEL ON JANOME 350E HARD TO TURN AND MAKE SQUEAKING NOISE THEN JAMS.
Have you oiled it lately? under the bobbin there is a white colored "wick" one drop of oil (maybe 2 now).
It also might be time for a professional service.
Sep 14, 2012 | Sewing Machines
Brother overlock sewing machine the hand wheel hard to turn how can we fix this
most of the time when the hand wheel is hard to turn, it needs to be serviced, to see if it needs cleaning or if there is some damaged part inside
Mar 20, 2012 | Brother Sewing Machines
When I try to hand turn the hand wheel it turns about half way around then gets hard to turn.
Are you turning it towards you or away? If, you are turning it away from you, you will mess up your timing, so never do that. Always turn it towards you.
Nov 21, 2010 | Singer 3116 Simple
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
50 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
