Question about Dryers
Dryer has very loud skreech after the heating ellement gets hot
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3inOne oil. Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
Posted on Oct 12, 2010
Dryer not getting hot
It could be the heating ellement(s)
They can be found by taking the back panel off.
Before doing ANYTHIG unplug the dryer to avoid injury.
Sep 20, 2012 | GE Spacemaker Washer and Dryer Electric...
My Maytag Neptune dryer, works fine until the last 5 to 10 minutes and then starts to make a loud skreeching noise. Suggestions??
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 18, 2011 | Maytag Neptune MDG9700A Gas Dryer
I seem to have about half the hot water volume I started with.
You may have one of your heating ellements burned out,with a volt meter check to see if you have 220volts at the ellement than unhook wires and check condinuity of the ellement.Check to see if your fill tube has fallen down inside the tank.The fill tube is located inside the tankat the cold water inlet
Dec 30, 2010 | Whirlpool Water Heaters
My Maytag Performa dryer is blowing out cold air. How can I fix it myself?
remove frt cvr,then top then remove drum belt and drum, check for open heater element, defective thermal fuse,hi-limit switch, open neutral to element if it uses the neutral connection
Oct 18, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
Dryer does not heat ellement is good
If the dryer won't heat and the heating element is good, then check the thermal fuse and the high limit thermostat. The thermal fuse is located just inside the rear of the dryer and is mounted on the exhaust duct. Test it for continuity using a multimeter. A lack of continuity indicates a blown thermal fuse. '
The high limit thermostat is a small round, black device mounted on a metal plate and attached to the internal ductwork with two screws. It can be tested for continuity. It should have none. If it has continuity it is faulty. I am attaching a photo of the thermal fuse and high limit thermostat for reference. Hope this helped and best wishes.
Aug 09, 2009 | Dryers
My dryer is making a very loud skreeching noise. it sounds like metal on metal. What could that be?
belt is probably off the drum. Take the back off and put the belt back on unless the pulley is bad then you can replace the pulley.
Jun 07, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
Dryer takes a very long time to dry clothes
dear sir you could check that your vent is clear and the trap outside is not closed or cloged to test your dryer disconect it from the vent if drys good then your problem is in your vent tubing if it does not dry when you have disconected from the vent then check the wire to the ellement most dryer have 2 ellement inside one may be broken this will take a long time to dry if you have a amp probe you can tell wrigh away by checking the total acording to the spec plate on the machine thanks from gilles
Mar 15, 2009 | Dryers
No Heat
yes possible ellement burnt out or themofuse burnt out thermofuse is a small white or black device witch is mouted od the back of the interior panel about 1"
longif it has ovrheat this fuse will cut out the power to the ellement or if the vent outside was cloged thanks from gilles
Dryers Logo
47 people viewed this question
Top Dryers Experts
