posted by homework17 on May 31, 2008
while cleaning i unhinged my kenmore ceramic oven door on left side.the door hinge one piece-claw-like. the oven part is two separate pins going across
Solution #1
posted on May 31, 2008
tough but you need to open the door all the way stick a small screw in the hole on the side of the hinge that is still on then partially close the door this will alow for you to remove the door and then you can push open with your hand the other hinge and stick a screw in the hole on the side this will keep the hinge from closing on you then reinstall the door
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
Coleman 5640B807 Compact Refrigerator
GE GSS25JEMWW Side by Side
GE GTS20ICNCC / GTS20ICNWW Top Freezer Refrigerator
Bosch Classixx KGV28323 Bottom Freezer Refrigerator
GE GTS22KBP Top Freezer Refrigerator
Haier (HTQ14JABRSS) Top Freezer Refrigerator
Haier BC112G Wine Cooler
Can you Help with these Refrigerators problems?
Kenmore 53642 / 53644 Side by Side...
Kenmore side by side...
Water from the dispenser tastes... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
