Question about Dream Maker Spas Dream Maker SpaDition Vico Pump 15 HP ()
I have a DREAMMAKER SPA (6 months old) with a 2 speed HYBRID PUMP. It has developed a high pitched whistle or whine when running. Is this a bearing? Could there be some stuff stuck in the impeller??
    Novelist:
  • 116 Answers
90% chance it is indeed the bearings. It is possible something could be stuck in the impeller causing noise, but not usually a high pitched whine. If you see water leaking, or calcium buildup where the pump meets the motor, then the shaft seal has failed and that is what's causing the bearing failure. Either way you'll need to replace the motor or have the bearings replaced. Look for a local pool pump repair shop (or some pool supply stores replace bearings as well). They should check the motor out for free and give you estimate to to repair/rebuild, or a price on a new motor if that's what you need/want. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Posted on Oct 12, 2010
Is a high pitched whistling sound at idle a vacuum leak or what?
hissing vacuum leak at idle, louder with open throttle ...
? 1:43
https://www.youtube.com/watch?v=tFoybr865n4
Jun 27, 2010 - Uploaded by fenixus
hissing vacuum leak at idle, louder with open throttle ... i know that my camera is poor and microphone suppresses high pitch ...Hi, my kia picanto engine also sound hissing/humming duringidling with open throttle. ... Loud whistling noise 2000 jeep wrangler 4.0l - Duration: 4:01. by Nasrac72 16,158 views.Missing: vt750c
A Whistle or metal sound with firing... - Honda Shadow Forums ...
www.hondashadow.net > ... > Technical Discussion
Jul 11, 2008 - ... under load (accelerating), that there is a small whistle or even 'tap on metal' high pitch sound ... Pics of my 2008 Shadow Aero 750 (VT750C ... loose bolt vibrating
Feb 29, 2012
High pitch whine
Jul 21, 2009
More results from www.hondashadow.net
Dec 25, 2015 | Goes Motorcycles
High Pitched Whine
A high pitched whine like that indicates a bad bearing. Water pump, power steering pump, accessory belt slipping, alternator bearing, or in the worst case scenerio, Transmission pump.
Dec 12, 2013 | 2001 GMC Yukon XL
1985 toyota mr2 engine noise
It still could be the throw-out bearing. When going bad, they have a high pitched whine or whistling, and if bad enough, could imitate a vibrating sensation. IDK, I would have a mechanic there listen to it.
Jul 12, 2012 | Toyota MR2 Cars & Trucks
I have a Waterway Spa Pump Executive 56 Frame 4hp Dual Speed PF-40-2N22C in a Catalina spa that recently developed an issue. The pump will not start in low speed, just makes a humming noise, but it will...
the problem with the sound is the bearings inside the motor are going out. i have the same pump and i have to replace the motor. replacing the bearings is very hard and will cost you about the same after you carry the motor and new bearings to a shop to be pressed in. hope this helps!!
May 04, 2011 | Waterway Spa Pump Executive 56 Frame 4hp...
Dishwasher Making Loud High Pitched Noise.
debris caught iside pump assy is what it sounds like
Feb 24, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
Dream Maker Spas Dream Maker SpaDition Vico Pump 15 HP () Logo
474 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
