When I turned my printer on, it says there is an error code 6202. My printer is a Kodak ESP 7250.
  • judih311554 Oct 11, 2010
    The first solution didn't work. It went back to saying error code 6202. I will be leaving for work, but I will be looking for an answer when I get home. What are the hours that you are available?
    Judi Hendrickson
  • judih311554 Oct 14, 2010
    I had to go to Kodak for help. They are replacing my printer.
    President:
  • 3,278 Answers
Hello.
Here's a solution from FixYa Support (shockwave727):
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already powered-up, the message "Printer access door" will appear
-Close the printer access door
-try to scan or print
If this issue is not solved, call Kodak tech support Toll free 1 800 421 6699
Hope this helps.
Posted on Oct 11, 2010
  • 5,081 Answers
6202 indicates that the SCANNER MOTOR has failed..
To resolve this error:
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Wait 30 seconds to allow the printer to reset.
  4. Connect the power adapter to the printer. Turn the printer on if necessary.
    • After the printer has powered up, the message "Printer access door open" will appear.
  5. Close the printer access door.
COURTESY:http://kodak-beta1.custhelp.com/app/answers/detail/a_id/1247
  • INDIRA KUMAR
    INDIRA KUMAR Oct 12, 2010
    We are available 24x7
  • INDIRA KUMAR
    INDIRA KUMAR Oct 15, 2010
    Please rate and accept my answer if you are satisfied..
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: My Kodak ESP 7250 has
Possible ink cartidge level being less.
Open the printer properties to check on the levels. If not remove the printer and connect once again affer shutting down PC.
If this wont work then remove printer, uninstall and reinstall, then connect to check if the printer is detected and installed.
If not drives are jammed/ the main board has errors..
Posted on Sep 12, 2010
Testimonial: "Thank you for your help. After trying several ideas last evening, I disconnected the printer, then restarted it and the problem disappeared. "
How do I connect to WiFi on kodak esp 7250 printer?
First turn on the wireless network on your printer. then searched your WIFI SSID input Password if necessary.
Mar 03, 2015 | Kodak ESP 7250 All-in-One Printer
I have kodak ESP 7250 ... Error light says printhead cartridge jam ... How do you fix ... I tried everything ...
When all else fails contact Kodak support and they can help you through this issue. The customer service number can be found in the instruction manual or online using "Kodak printer repair".
Nov 14, 2013 | Kodak ESP 7250 All-in-One Printer
Error code 6202
Thank you for contacting FixYa printer support. Error: "Printer error" (6202) Published 08/25/2010 11:38 AM ' Updated 05/20/2011 09:04 AM ' Answer ID 1247
How do I resolve the error message "Printer error" (error code 6202)?
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary.
When the printer is ready (no error message), upgrade the firmware for your printer:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
If the error continues and you cannot upgrade the firmware, contact Kodak Technical Support.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jun 11, 2011 | Office Equipment & Supplies
On a 7250 have error code 6202, having..
When the printer is ready (no error message), upgrade the firmware.
If the error continues and you cannot upgrade the firmware, contact us.
Feb 01, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
Mi impresora kodak Esp 5 Muestra en su pantalla " error de la impresora" Código de errro 6202" ¿Qué hago?
To quote Shockwave727:
to solve this
-Unplug power cable
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Sep 28, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
My Kodak ESP 7250 has been working fine but suddenly came up with Error code 6202.
Sep 12, 2010 | Office Equipment & Supplies
Scanner motor move failed error code 6202
to solve this
-Unplug power cable
Nov 07, 2009 | Kodak ESP 5 Printer
Setting up a new Kodak All In One printer and keep getting error code 6202
Hi!
This is a error message of the scanner.
1. Turn printer on.
2. Unplug ac adapter.
3. wait 1 minute.
4. Plug ac adapter in printer.
5. wait until the printer is ready.
when the error still occurs, the printer is definetly defect.
Jun 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
481 people viewed this question
jasbo
jasbo
