Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
BLINKING STANDBY LIGHT AND NO POWER
Standby light blinks but the tv won't power on.
  • vrixe Jun 30, 2008
    Same problem. Blinks 9 times. Help!
  • jonnyshakes Jul 25, 2008
    light blinks 9 times every couple of seconds.
There is alot of info re: this problem & what repair is needed at
agoraquest.com
Posted on Aug 14, 2008
My Sony tv won't switch of standby just flashes
How many times do this standby light flashes at one time switch ON? Count this and make sure, how many times it blinks. These blinks are fault indications. From these number of blinks, you will get an idea about the faulty section circuit inside it. It will narrow down the troubleshooting. If you wish to get more details about Sony Blinking Codes; check this link.
Feb 17, 2013 | Televison & Video
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Jul 03, 2012 | Panasonic TC-P50X1 50 in. Plasma HDTV
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony kv36xbr800 won't turn on -standby blinks 2 times pls help
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Apr 22, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
MY LCD PHILLIPS MODEL 42PFL3704D/47
Good day!!!
if you have power problem without blinking lights or standby lights (red) the possible problem is power supply board..However if the TV have blinking or standby light but won't turn ON..there are multiple cause of that and need further troubleshooting..
Mar 11, 2012 | Philips 42PF9431D/37 TV
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a sony 65 in. sxrd projection tv that has the red power light blinking and the tv won't come on?
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 16, 2011 | Sony Televison & Video
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
123 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
