Question about HP Compaq nc6320 Notebook
Har drive problem
When i power on the computer it will not read the hard drive installed in the computer but it will read the hard drive from a USB source. is there any way to fix this?
  • SuchIsLife Jun 02, 2008
    I was able to get into windows until i tried to get rid of the startup password, now it wont let me into windows. When i tried reinstalling windows it got started and then said the hard disk is locked and i can't figure out what is wrong?? I can start up from the disk drive.
  • anshumannn Oct 09, 2008
    when i boot my laptop it don't read the hard disk?
    Problem Solver:
  • 5 Answers
Check your bios for startup order
Posted on Aug 08, 2009
THE COMOUTER READS NO OPERATING SYSTEM I INSTALL IT WITH NO OS THE COMPUTER READS THE DRIVE BUT I CAN NOT INSTALL AN OPERATING SYSTEM
  • You should have an operating system install disk (or USB drive.)
  • Restart the computer and press whatever key gets you into Startup (typically F2 or Del.) You *may* have an option that says "Boot menu" that has another key (such as F12.) If you have that, use it.
  • Find something in your BIOS that mentions "Boot order" or "Boot priority."
  • If you have a CD, make your CD the first boot device. If you're booting from USB, make it your first device.
  • Make sure your install media is in the computer, save and exit.
  • The computer should now boot from the install drive and put the operating system on the hard drive.
Mar 24, 2016 | Maxtor Hard Drive
My pc is not reading the external drive. My previous shortcut is not responding. I have tried multiple usb connections.
If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected. Hope this helps.
b>
Dec 16, 2012 | Computers & Internet
I want to turn a memory stick into hard drive. How can i do that?
you will need usb data drive at least 4 - 8 gb
Download the GParted Live utility and the HP USB Format Tool via the links in Resources.
http://www.majorgeeks.com/downloadget.php?id=5757&file=15&evp=fb0a8fee133295405b5af3205e8d2424
Insert your USB stick into the computer. Run HP USB Format Tool. Select your USB stick and then choose the FAT or FAT32 format options. Click "Start."
Extract the files from the GParted Live zip file. Select the USB stick as the destination.
Open a file browser and navigate to the USB stick. Select "utils" > "win32" > "makeboot.bat." Double click on "makeboot.bat." Enter "Y" when prompted.
Power off your computer leaving the USB stick inserted.
Connect your portable hard drive to another USB port.
Power on the computer and quickly press "F8" through "F12" to access your boot menu.
Check your computer or motherboard manual for the exact keystroke.
Select the USB stick as your boot source and press "Enter." Allow the Gparted GUI to start.
Select the external portable hard disk drive. Click "Partition" on the menu bar.
Hover over "Format to" and select "NTSF."
If you are unable to create or format the partition, select delete partition.
This will erase all data on the external hard drive. Confirm partition deletion. Select the external drive again. Click "Partition" and hover over "Format to" then select "NTSF."
Select the external hard disk drive again. Click "Partition" on the menu bar and then "Manage Flags." Check the box next to "Boot." Save and apply changes to the drive.
Power off your computer and remove the USB stick.
Install the OS
Insert or plug your OS installer, usually a DVD, CD or USB thumb drive, into the computer. Power on the computer and access the boot manager again.
Select the source containing your OS installer and press "Enter."
Enter your personalization and registration information if required.
When prompted, specify the portable hard drive as the install directory.
Begin the installation normally.
Restart the computer when prompted and access the boot menu again. Select the external hard drive as your boot source and press "Enter" to ensure the installation succeeded.
Use this process to boot from your portable drive on any computer.
hope this helps
Oct 02, 2012 | Sony Vaio VGNBX196SP
How do I get a users manual to learn how to fully operate my new iomega desktop hard drive
According the the website, the manual is on the drive. To get to it all you need to do is first plug power into the hard drive. Then plug the USB cable from the hard drive into the computer you are using. Then go into My Computer and select the drive. You should see the manual there. If you cannot read the file download this and install this: http://get.adobe.com/reader/. It is a pdf reader which is what the manual file is going to be.
May 12, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
Hard drive keeps beeping and not recognised by the computer
Hi check on the device manger id the hard drive is being received by the computer. If it is listed then re-install the driver for it.
If it is not listed on device manger , try a different cable, try a different USB port. Try it in another computer or xbox/ps3 to see if it can be read by them
Also...
Re-install it into another caddy to make sure it not the caddy USB port damaged.
If the hard drive is making a loud noise, the hard drive may be damaged. It may also be the hard drive controller damaged.
May 07, 2011 | Iomega (33600) 160 GB USB 2.0 Hard Drive
DC-IN port is broken and I am looking for a USB power source so I can power up machine and download pictures from hard drive to another external drive.
You cannot power up your computer from a USB port. You can remove the hard drive and use a USB hard drive adapter to hook up a CD or hard drive and have it read by another computer.
Nov 03, 2010 | Toshiba Satellite M35X-S311 Notebook
How can I turn my netork hard drive into a External hard drive
Network hard drive is also an external har drive but its shared over a network. If you want it to be used a external hard drive connected directly to you computer, read below.
Your WD drive should have a USB port on it. You need to plug the drive into your laptop directly to be used as a external hard drive.
Please rate if helpful.
Thanks
Apr 19, 2010 | Western Digital My Book Essential 1TB...
The computer doesn't read the flash drive when i plug it into the USB port
go to my computer property then hardware then device manager then uninstall usb drivers and install again
if u find unknown device u must have to install proper flash drive driver
May 22, 2009 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
Not able to read on my laptop ,but used to be able to!
  1. Maybe you need to restart your computer and try to add hardware in control panel.
  2. try to unplug and plug again your usb connection to your hd and computer. There's some possibility that your usb cable or something relating to it is error.
  3. Is it need a driver?. If so, install the driver.
May 10, 2009 | Computers & Internet
HP Compaq nc6320 Notebook Logo
103 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
