Question about Akai PT4298HD Rear Projection Television
Tv won't turn on.
What should I do? Akai PT4299HD won't turn on
  • 11 more comments
  • Frank Pisani Jun 05, 2008
    I have the same problem. My TV will not turn on. I do not get a picture of sound. The red light is on but no light on the screen.
  • Anonymous Jun 18, 2008
    same problem red light is the only one on.please help.
  • csutyak Jul 28, 2008
    I was watching the tv when the screen went black and no sound.
  • YoungBird Aug 04, 2008
    My T.V. went out yesterday. It will not turn on and there is no sound. I can't find mannual, can you help?
  • DKENT Sep 11, 2008
    I HAVE THE SAME PROBLEM T.V WONT TURN ON , RED LIGHT IS ON . IS THERE A RESET BUTTON OR WHAT? THANK YOU...
  • cons529 Nov 26, 2008
    Not to sound like an echo here, but my TV is doing the same thing.
    Red light on, the 'turing on' sound is there, but there is no picture or sound.
  • pdou5360 Nov 30, 2008
    tv wont turn on.has green light on showing power.makes a sound but no picture and no sound
  • craig_climbr Dec 02, 2008
    when i turn on my tv the red light comes on but no picture. how much is it going to run to get it fixed. or would i be better off buying a new tv
  • mckenzie6640 Dec 02, 2008
    my tv just went blank with no sound. the red light on the front comes on but then goes off. any suggestions?
  • jacklwatkins Dec 10, 2008
    red light is on and then goes off, tv will not turn on. Is there a quick solution. thank you jack watkins
  • dettestelly Jan 10, 2009
    Red light mystery. Man I have the same problem. The local repairman kept my tv for about 3 months, said the high voltage transformer needed to be replaced. The part # on the tv is FFA61513L but could not find it. He called Samsung and got a equal part # which is BP26-00015A. The problem is the part takes 6 weeks to come in, if they have any. He said the part has been discontinued.
  • jazzylady32 Jan 20, 2009
    Hi Chris. I have the same problem. The TV just went off on it's on. The button is red but won't come on. The repair shop has had my TV for 2 mths now and they are having a hard time getting support and the part needed. I have a 32" LCD series ZXPro Series model LCT32Z5TAP. What did you do to resolve your issue?
  • Anonymous Feb 18, 2009
    Trying to find a master reset or something to restore it to factory settings but cant find anything... Please help!
    Problem Solver:
  • 10 Answers
I had and l32n series tv with the same problem, im an electromecanical engineer. the problem can be solved by opening the tv, and on the power supply board, on the upper right there are 3 or 4 capacitors, brown or blue, change which ever looks like its about to blow up. you can tell if the top of it in NOT flat. those that still have the flat top are fine. check the voltage and replace it with one that has 5volts more than the one you took out. im located in NY if you want me to do this for you reach me at www.joanoc.com
Posted on Jun 10, 2010
I had the same problem today, had a burning smell and blacked out. When I tried to use the power button, it wont turn on... Please help!!!
Posted on Sep 12, 2008
SAME PROBLEM RED LIGHT
Posted on Sep 09, 2008
How do I connect my PT4299HD to my laptop?
Might help to know what make/model laptop you want to connect to your Akai projector?
Oct 18, 2014 | Akai PT4799HD Rear Projection Television
How do i get the lens to converage for akai mdl pt4299hd
Well the problem is also, they play high quality in a store and your tv is just hd, that's why i don't waste money on a expensive tv. And be smart, buy a two hundred dollars device two make your tv or pc , the best as it can be .
Oct 12, 2014 | Akai Televison & Video
Akai pt4299hd
Try recycling the power, Unplugg the power cord wait at least 2 mins ant then plug back in. Some times by turning it off an on rapidly will cause the microprocessor to lock up or freeze. Much like a computer does when you have to reboot it..
Sep 25, 2009 | Akai PT4298HD Rear Projection Television
What is the samsung cross for a akai pt4299hd
Samsung = PT4299HDX/SMS and also PT4299HD5S/SMS
May 21, 2009 | Akai Televison & Video
Pt4299hd wi game compatible?
The answer is yes. I have the PT4799HD and the wii system and it works just fine. It is currently hooked up to the analog audio video input . But a HD cable is available for the wii as an accessory.
Feb 21, 2009 | Akai PT4799HD Rear Projection Television
My akai pt4299hd tv stopped working. it will not come on.
On AC power supply board there is 2 thyrisitor poor solder ,I have repair several of these with that problem.
Nov 20, 2008 | Akai PT4799HD Rear Projection Television
Akai pt4299hd
replace your STKs big black Ics STK394-250 there is 2 of them thses are your convergence ics.Also ck resistors and pico fuses.
Jul 22, 2008 | Akai PT4799HD Rear Projection Television
Akai hd projection tv pt4299hd won't turn on
Sounds like a power supply issue. Does the power indicator light up? Can you hear a click when the power button is pressed?
May 31, 2008 | Akai PT4298HD Rear Projection Television
Akai PT4298HD Rear Projection Television Logo
403 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
