Question about Canon PIXMA MP510 All-In-One InkJet Printer
HOW DO YOU GET THE INK CARTRIAGES TO COME OUT SO I CAN CHANGE THEM??? I am using a Canon mp510 usually you just open the lid and they move to the middle where changing them is easy.
    Scholar:
  • 48 Answers
Lift the top cover and you will see the cartridges toward the center of the printer (they are long thin ink tanks with different colored labels). On the side of the cartridges facing you there are tabs that you pressin and then lift that side up. Then you can pull the cartridge out toward you. To insert the new cartridges, simply make sure the side with the tab is facing you and slide the cartridge into the corresponding slot. Then press down on the cartridge where it says "press" untill it clicks into place. A red indicator light should come on if you did this correctly.
Hope this helps! Good luck!
Posted on Oct 11, 2010
Mp510 waste ink needs emptying
Ink Absorber Full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Jan 22, 2013 | Canon PIXMA MP510 All-In-One InkJet...
Need to print only black ink on canon mp510
in the printer set up ( normally in the print section , change the color to black and white , make default and ok
Jan 11, 2012 | Canon PIXMA MP510 All-In-One InkJet...
Can't find my manual and don't know where the ink cartridges go, my printer is a Canon MP510
Your printer must be turned on.
Open the printer by lifting the whole scanner assembly. The Carraiges should move into position so that the cartridges can be inserted.
Aug 23, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA MP510 : When I print something in colour, I get alternating dark and light 3mm lines printed horizontally down the page. I've tried cleaning, deep cleaning and realigning the print...
Hello
what you need is to clean, you need to clean the prnt head and ink cell, you open the top part let the ink carrier move to the center then UNPLUG the power cord ,now you can easily clean ink cell.
Jun 29, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Canon pixma mp510-when switch on -grinding sound - then error 5C00 message - when open cover - ink assembly unit does NOT move to center - please advise
The purge unit is blocked,the purge unit is on the rigth if you open the scanner.You must unzip the printer to look at the purge unit.In the main part you need to replace the purge unit.If i have been useful please give me a vote :).Thanks
Apr 03, 2011 | Canon PIXMA MP510 All-In-One InkJet...
How do i change the ink cartridge in my canon mp510 printer
  1. Press the "On" button on the top panel of the printer to turn it on. Open the paper output tray at the front of the printer.
  2. Lift the entire printer cover, which should snap open. Then lift the small inner cover.
  3. Press down on the tab below each ink tank to snap out and remove the tank. Lift the print head lock lever that holds the ink tanks in place.
  4. Lift the overflow tray toward the top of the printer and slowly pull it out of the printer. Take care to avoid spilling any ink that has collected in the tray.
Good Luck!
Sep 27, 2010 | Canon PIXMA MP510 All-In-One InkJet...
The black ink is not printing on my canon mp510 even though there is ink.
sounds like the black ink jet is blocked with dried ink, use the maintaince tool, should be in the canon software
Sep 12, 2010 | Canon PIXMA MP510 All-In-One InkJet...
How do I change the ink cartridges in a Canon MP510 printer?
palese you are open the head couver and old cartridge is out of printer in holder and add a new cartridge when old cartridge palace in atech
a new cartridge and start printer and aply a prient.
Oct 23, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Lcd says lid open when it is closed and I want to scan
There is a little switch that a pin or similar part on the lid activates. There is usually a small hole with the switch under. If the pin is broken or the swich has moved it wont work.
May 12, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
55 people viewed this question
old marine
old marine
