Question about Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer
How to replace ink absorber pad for brother dcp135c printer
  • 525 Answers
No necessary at all.
Posted on Feb 02, 2011
  • 5 more comments
  • Anonymous Feb 02, 2011
    There is no necessary to replace ink absorber pad, just reset with this procedure:
    the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
    1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
    2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
    3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
    4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
    5. press Stop/Exit key to go to root of maintenance mode
    6. enter 9,9 to exit maintenance mode
  • 6radleigh Feb 10, 2011
    This seems to have solved my printers problem.
    Thank you!!
  • dimine Feb 12, 2011
    thank you. I followed the steps and solve the problem with error 46.
  • gashead007 Feb 25, 2011
    this worked, big thank you, as it save me best part of £70 what it would have cost to replaced pad
  • ogho Mar 29, 2011
    works fine here also, but can I be sure not to find inc all over my table next week?
  • robibbii Jun 02, 2011
    Worked like a dream.Thx so much
  • mskx Aug 26, 2011
    Worked fine, thank you
What to do if it always appear in the monitor of the printer that ink absorber is near full?
Not only the absorber must be cleaned, also the counter must be reset. I know there is a program for older Epson printers to reset the counter. I found a reset procedure for a brother printer here:
How to Reset Purge Counter on Brother DCP J315W Printer
Perhaps you can fine one for yours?
Feb 21, 2015 | Brother DCP-J125
I have never heard of replacing ink absorber pad? My printed has stopped because it says the absorber pad is almost full. Where can I buy, how do I fix
When you select clean print head the ink that is pushed through it is collected by an absorbent pad directly under the print head This pad can be removed, washed with water and reinstalled after it dries.
Nov 02, 2014 | Brother MFC-J4710dw All-in-One Wireless...
Brother MCF-J4710DW says ink absorber almost full and won't print? Never heard of ink absorber. Where can I purchase replacement and how do I do it
Many ink-jet printers have a pad in the case to absorb the ink from cleaning cycles. Often these show "full" long before they are actually full, and you can reset the counter and continue using them. I found your answer here:
How To Reset Purge Counter on brother mfc j4710dw
Nov 02, 2014 | Brother MFC-J4710DW 35ppm 6000 x 1200 dpi...
Ink absorber full
This video shows you how to reset the counter so your printer will work again. However, it doesn't solve the problem of your absorber being full of waste ink. I recommend placing the printer on a towel in the event that the absorber overflows. This will avoid ruining the table your printer is sitting on.
http://www.youtube.com/watch?v=1NzJwuCpVOc
Here is the parts list if you wish to order the pad. It will take most of an afternoon and be very messy. Not for the novice. Your best bet is to reset the printer and use it until ink physically leaks out of the machine - then replace it.
http://support.brother-usa.com/ModelDocuments/Technical/Parts%20Manual/PM_DCP_J125_MFC_J220_J265w_J270w_J410w_J415w_J615W_J630W_EN_5179.PDF
If you do fix it yourself. You will need the following:
http://www.sparepartswarehouse.com/Brother,Printer,Part,LS4699001.aspx
http://www.sparepartswarehouse.com/Brother,Printer,Part,LS5136001.aspx
I have no experience with this vendor. It's just the first one that came up in Google that wasn't in the UK.
Apr 19, 2014 | Brother DCP-J315W Inkjet Multifunction...
My brother dcp-330c was unable to clean 46
If you are giving the error as 46 see below the error chart fix. I hope this gets you going and thanks for using Fixya. The number is 800-284-4329 What the error is saying is shown below. I copy and pasted so let me know if it doesn't show up for you and thanks for using FixYa.
Error 46 Ink absorber pad is full...replace it contact brother customer service.
46 The ink absorber pad is full and needs replacing. Please contact Brother Customer Service from "Contact Us".
Jan 26, 2011 | Brother Office Equipment & Supplies
The Ink absorber pad of my Brother MFC-240c printer is full. How do I replace it and where is the pad located?
I have all pads removed but I having difficult time finding new pads, no local supplier here in London, Ontario,Canada, found one supplier in the United kingdom for £11.99/$30.00, not sure if this is reasonable cost, I also need the pad which is located at rear of ink cartridges. Any advice/direction wil gratefully appreciated, thanks, Mark.
p.s. I have a MFC-240c all in one brother printer
Jan 07, 2011 | Brother Multi-Function Center MFC-240C...
How do I replace the ink absorber pad, where in the printer is it.
Hi There
To get at the ink pads all the printer goto be taken apart it a big job, you cant miss the ink pads when you open the printer apart it one big mess of ink there.
All the best Pineworks
May 02, 2010 | Brother DCP-135C Flatbed Digital MFC...
Brother DCP-135C Error message CLEAN UNABLE 46 How do I clear this please. I don't want to pay for an engineer. Thank you.
The error you are getting is telling you that the
Waste Pads have to get replaced because they are saturated with ink.
The sets of pads run under $20. The Upper set of Pads is not too hard to replace, you need to take the scanner assembly off, upper cover and control panel and the flushing box is in the back. The second pad requires taking out the printer mechansim and platen roller , bottom plate and possible removal of printhead. I do not recommend you doing this.
The unit then needs to get reset.
thanks
May 02, 2010 | Brother MFC-5840CN All-In-One InkJet...
You need to replace the waste ink absorber and then reset the counter. These can be obtained from some suppliers of ink and spares etc, otherwise you will need to contact Brother in your country or take the unit to a service engineer.
Generally when these errors occur the waste ink absorber needs replacing, if not your images will start to degrade in quality and you will start to see ink splays / splodges appearing as well as random spots and ink patches. In the mean time press RESUME /CANCEL to continue printing.
Oct 02, 2009 | Brother MFC-5440CN All-In-One InkJet...
What is a The waste ink absorberves
The waste ink absorbers on a Canon are a set of pads underneath the entire printer engine, they cover just about the whole bottom of the machine, on a Brother it's a replaceable box filled with absorber pads. Both have to be replaced by a shop to reset the counters and clear the error.
Aug 11, 2009 | Office Equipment & Supplies
Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer Logo
1,840 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
