I have Beko AA WMD 25060 washing machine that refuses to open the door. It seems like it is stuck on the "spin"-led, after I tried resetting by holding down the start button for 3 seconds. It's been trying to empty the machine for nearly an hour now, but it seems it won't go out of this mode. I have also done all the check in the manual, without success (checking filter, pulling the plug for 5 minutes, etc).. Is there a way of resetting the machine completely?
  • 1294 Answers
SOURCE: Zanussi Washing machine
Try some WD40 on the door switch.
Posted on Jan 25, 2008
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
  • 6 Answers
SOURCE: beko WMA 1715s - won't respond
door lock switch could be your problem..
Posted on Aug 30, 2008
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
  • 9 Answers
SOURCE: Beko washing machine will not complete wash cycle. it will not rinse anf then spin. You have to manually select spin and drain after wash is done. can the maching be reset in anyway.
your timer is most likely bad
Posted on Apr 20, 2009
My beko wmb61431s will work in spin or rinse mode
check the clutch, the belt, the motor coupler, the door switch,
Feb 25, 2015 | Beko Washing Machines
Wm74135w stuck on last minute
If the washing is unbalanced the machine will either not spin it or seems to spin forever. This is not a fault. Pause the machine - wait for a minute to see if the door will unlock - if it won't cancel the programme and wait another minute. Re balance the load and try again if needed.
Jul 06, 2014 | Beko WME7247W Washing Machine
Beko stuck on spin and drain,just fill again aa class 1000rpm
Try cleaning water pump filter it's probably blocked use the filter drain hose to empty .
Jul 05, 2014 | Washing Machines
Aa class beko washing machine wont spin or start a cycle
This Beko washing machine video will help you
We work very hard in our warehouse making free video guides for you all on cookers, ovens and washing machines Etc. Buy Paul Beer
Apr 02, 2014 | Beko Washing Machines
Beko 5100 w-5100 s door jammed
Try further spin/drain cycle then try door again. If no go, sounds like door lock switch may have jammed. Have to have lid off and see if you can unlatch the door manually.
May 19, 2012 | Beko Washing Machines
Have a Dometic WMD 1050 front load washing machine and can not open the door
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 26, 2009 | Washing Machines
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Oct 19, 2008 | Washing Machines
Beko WMA 1715S
try unplugging and let it reset itself
Apr 03, 2008 | Washing Machines
Washing Machines Logo
132 people viewed this question
Top Washing Machines Experts
