Question about Century "Bob" Body Opponent Bag
The fixings at the back of my century bob are coming away from the latex due to turning the torso square between blows. I did not realising this was putting pressure on these fixings until I looked at the back and saw it was starting to tear..
When front air is on rear heat always
If you have owners manual check that your climate control settings are as you expect them to be, if that makes sense. Some on Fixya do not realise they gave climate control , they think they have normal A/C and try to correct chimerical problems. Please check and repost
Jul 03, 2015 | 1997 GMC Savana
Spray gun problems
You basically have what is called a "cupgun" and there are a few reasons for this and it should be pretty simple to fix I want to stress that anytime you spray the paint no matter what latex-oil needs to be thinned with the compatible solvent water for latex paint thinner for oil/Alkyd by about 10% - 18% that could be the problem if you have latex in your gun but probably it has to do with the "needle seat" in the back of the gun there should be a knob to adjust the needle turn your gun on pull the trigger and turn knob till paint comes out if that wont work you may have debris in your paint that has clogged the stem pour all the paint out clean gun completely pour paint threw a strainer cone or strainer bag and be sure to thin it...
Sep 01, 2014 | Wagner Paint Sprayer. Flexio 570 HVLP...
What is a torso track?
Torso track is a very effective equipment for working out the abdominal muscles. According to a study done at San Diego State University, using the torso track is more beneficial than doing regular crunches. Using the torso track, you basically need to place your hands on the handles and slide back and forth.
Aug 15, 2012 | Exercise & Fitness
What is a BOB punching bag made out of?
Both the base and pillar holding the torso are made from high quality plastic that is very strong and sturdy. The torso section is made from rubber. They are designed to be as lifelike as possible, so usually the torso is made from a harder rubber than the face section.
Aug 07, 2012 | Boxing
Century bob
Cheap plastic nipples are stripped out! Moving it while Bob is still attached & kids jumping on Bob's shoulders did the same to mine... I am going to try short bolts & nuts after dipping in plasti-dip/rubber product of some sort.
Nov 21, 2011 | Century "Bob" Body Opponent Bag
How to fix running lights on a 1999 buick century
I just fixed the forward running lights on mine. Running lights are same bulb as the turn signals. There are 2 white clips holding the light assembly onto 2 square studs. Pull both clips upwards about 1/2 inch and the assembly should be able to be pulled out. Remove black round rubber cover, grip the light socket assembly and twist aprox 1/8 turn and it will come out. Replace bulb. I put a little dielectric grease on the spade part to prevent corrosion. Test and reinstall assembly in reverse order. If the white clips come off easily this is an easy do it yourselfer!
Hope this helps Ken
Dec 08, 2010 | 1999 Buick Century
How do I fix my calculator if I can turn it on but cannot turn it off and press any button after I turned it on?
do you have a solid black square in the top left corner?
if so, blow hard into the I/O port on the top of the calculator. That fixed the problem for me.
Sep 22, 2009 | Texas Instruments TI-83 Plus Calculator
My Playstation 3 turns on, and stays on for about 4 minutes then cuts back off
Generally when a system turns its self off its trying to prevent damage to the system due to either a short or due to heat. My suggestion would be try running your PS3 in a different location first, such as, if its on a shelf move it to the floor just to put it in a wider area where its less likely to overheat, secondly check to make sure its power supply adapter isn't whats causing the short. That also has a built in sensor to protect it from starting fires and / or damaging your hardware. If with both of those out in the open, possibly in a colder room - (I realise its starting to heat up and thats probably the reason this is just starting) try running it, and if the problem persists, then its your PS3 going bad and there is nothing I can do to help, but, on the other hand if it stops you know that you need to change your setup to accomodate for the heat, whether its turning on some air conditioning or placing a fan besides the PS3
*note when using an external fan in conjunction with the PS3 it works best to have it blowing away from the PS3 - that way it is sucking the hot air away from the machine rather than blowing the hot air back into the machine.
Hope this helped and if it didn't feel free to leave a comment and I'll get back to you as soon as I can =)
Jul 18, 2009 | Sony Playstation 3 (PS3) Console
Black Square
I had the same problem with DVDs. It turrned out that I turned the closed caption on a few days earlier, so I turned the "closed caption" off and the problem went away.
Jan 30, 2009 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Century "Bob" Body Opponent Bag Logo
Top Century Sport & Outdoor - Others Experts
Are you a Century Sport and Outdoor - Other Expert? Answer questions, earn points and help others
