Question about Sharp AR208D Copier
I have an error code H4-00 error code on my fax machine model # Sharp AR208D. How do I clear it?
    Problem Solver:
  • 9 Answers
Call To This Nubmer:- 9833071224
Posted on Oct 11, 2010
Our copier is an AR-208D & it has a error code of H4-00 displayed. Can we fix it?
In most cases the flashing H4 or H then 4 code on these machines is caused by voltage fluctuations or surges. Normally there is nothing wrong with the machine and the code is easily reset. Here is the procedure:
Press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "#" then the " * " (star) key then the "Clear" key then the " * " key again.
So in other words #, star, C, Star
If done correctly the display should go blank.
Then key in 14 as if you were going to make 14 copies.
Now press the "print" button
The machine should automatically shut down and restart with the H4 code being gone.
If the H4 code comes back after reset then in this case you have a fusing unit problem and will need to have the unit serviced.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 22, 2010 | Sharp AR208D Copier
How do I clear the Maintenance Required message from the screen
the machine is due for a drum cartridge and a cleaning. but to reset the message press---(#),(*),(c),(*)2,0,(start or O.K.)1,yes to reset. Then the yellow CA button.
Dec 14, 2010 | Sharp AR208D Copier
I cannot receive faxes, but can send them.
Courtesy www.brokenfax.com :
Sharp ram clear (most models with LCD displays)
Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Best of luck and hope this solves your problem.
Greg
Jul 24, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
I have an error code coming up E32. I have pressed the clear button but it is not clearing. I can not enter anything under any department.
Hi Skitso,
The problem is listed as afax machine error but the error code quoted seems more to be that of an error on a cash register.
If this is correct and it is a Sharp cash register the error is telling you that you need to enter your clerk or cashier ID.
For ease of reply try pressing the "1" and then the CLERK ID key.
Regards
Gavin.
Oct 08, 2008 | Sharp Office Equipment & Supplies
Sharp FO5700
I have never seen this error code on a sharp FO 5700 are you sure that is the right model # or error code. I even did a search in the FO5700 service manual(no luck). I believe I have seen this code before on a sharp copier.
Sep 05, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Line error
I have a Sharp UX-300. When I get a line error, the easiest way to clear it is to unplug the fax machine from the power outlet and let it stand for at least a minute. Then plug it back in to the power outlet. If this does not clear the problem, use a regular phone to check if the phone line between the fax machine and the wall is 'OK'.
Nov 15, 2007 | Sharp UX 355L Plain Paper Thermal transfer...
Sharp AR208D Copier Logo
141 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
