Question about Kitchen Ranges
Troy Bilt pressure washer 2600psi-2.3gpm from Lowes. It starts up fine but stalls under load every time I try to spray. Then it is more and more difficult to restart and finally stalls out when not under load. Any idea why?
    President:
  • 239 Answers
Hello, this area is not within my expertise but I have spent some time reading articles online, so rather than plagurise, I shall send you the links.
http://www.ehow.com/how_5332920_troubleshoot-troy-bilt-pressure-washer.html
http://www.fixya.com/support/t1883465-troy_bilt_2550_20293_pressure_washer_not
Hope this helps
Jim
Posted on Oct 11, 2010
Engine starts then stalls after 3 or 3 minutes of spraying. Then when I try to restart pull cord is really hard to pull.
When starting make sure you pull the handle to spray so it relieves the pressure from the pump an engine
Dec 19, 2015 | Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure...
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
My troy-bilt 20486 pressure washer runs but does not spray water
OK just so we are on the same page.
You did turn on the water (right?)
Jun 12, 2014 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
Troy bilt 2550 psi pressure washer My friend gave
Try this link. I think you'll find what you're looking for.
http://www.troybilt-gen-pw.com/owners_manual/
Nov 04, 2013 | Garden
Troy-Bilt pressure washer does not provide pressure
Sounds like your pressure pump is shot. Replace it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/anthony_e4f197748c31eabd
Aug 29, 2017 | Briggs & Stratton Garden
Power washer stalls after spraying
Your pressure relief valve may not be working. If that happens when you shut off your spray gun, then pump is dead heading, stopping the motor. If this is the case it stops dead, not coasting. Either replace the pressure adjusting relief valve or remove it, and disassemble it and clean it.
Jul 18, 2010 | Honda Pressure Washer PSI 3000
I HAVE A BRAND NEW TROY-BUILT 2600PSI pressure washer. I have used it twice for about 1/2 hour each time. It worked perfectly. I tried to use it today with everything hooked up perfectly. The Honda engine...
Sounds like the governor is stuck. My pressure washer speeds up when it has to pump. Don't know if yours uses vacuum to trigger governor or direct linkage. Good Luck.
Jul 04, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Kitchen Ranges Logo
296 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
