Question about HP V72 17" CRT Monitor
I got a hp v72 monitor i have a problem when i play games, the games loads then u can play for like 5min then the monitor shuts down, the light switches to orage and i tried to touch the monitor and hit a key stroke doesnt work, i have to switch off the pc then back on to work again the its ok after that, the only game that i can play us cossacks 2 thats it, i have updated everything on my graphic card and monitor still the problem.
  • HP Master
  • 1,186 Answers
No PC stated
No OS (op.sys) stated
V72 old old old CRT cathode RAY monitor , go to walmart get new $60 monitor. now fixed.
https://h30434.www3.hp.com/
that old useless monitor does not comply to VESA video standards
so fails. on my guessing modern unstated PC
or is bad. most this old are bad, the fact that it runs at all is
a , amazing !!!!
Posted on Jul 05, 2017
  • 97 Answers
SOURCE: Monitor using 100% cpu and on the blink
Video card is plugged via DVI cable? If the board in the flat panel is going bad ( main signal pcb) video card can be going up and down scale to control its sync with no luck, causing the CPU useage problem.Only ever seen this once. Normally, the monitor will not cause and performance issues other than you cannot see anything.
Posted on Apr 29, 2007
Benimur
  • 6966 Answers
SOURCE: HP Monitor blanking out on full screen mode
Hi, I read this somewhere (can't recall the site). Go to your desktop properties (right click on any clear area of your desktop); Settings tab; Advanced button; Troubleshoot Tab; Uncheck Enable Write combining; Reboot your PC. If this does not fix the problem, you can always revert back. Hope this be of some help. Good luck and kind regards.
Posted on Jul 30, 2007
Mark_Webber
  • 472 Answers
SOURCE: Going to Sleep
Due to the power surge, it is highly possible that the monitor was given a boot by your computer on it's way out.
This will short out a very small transistor inside the monitor on the video board and in turn, then monitor cannot see that there is a signal so goes to sleep.
If you get brave enough to venture inside the screen, then check near the cable input. The transistors are only around 3mm and have 3 legs (two one side and one in the middle on the other).
If you find anything like that burnt (get a magnifying glass) then replacing the board is the easiest option. Just don't be tempted to wipe the board before you look at everything very closely, you may wipe away the tiny bit of evidence you are looking for.
Hope it helps =)
Posted on Apr 09, 2008
aouate3
  • 123 Answers
SOURCE: my screen stays black but my pc is on
it sounds like your mointer is ****, i highly doubt the game caused it. try another mointer, or sell that one on ebay and buy a new one
Posted on Jun 14, 2009
  • 60 Answers
SOURCE: I play Combat Arms and am having monitor problems.
Put off the Monitor once more and get the proper performance.. Coz the some time the resolation is not matching..
Posted on Jul 10, 2009
Monitor shuts itself down, "no signal" message.
nope. the resolution has bumped up for some reason out of range for the monitor. Does it only happen in the game? that might be a clue.
Feb 17, 2014 | Envision 19" Lcd Monitor H1981
I have a desktop PC with HP v72 monitor and a GeForce FX 5200 video card installed. I uninstalled Windows XP and installed Ubuntu Server 11.04. The problem is that after the initial boot screen my monitor...
why run server, , sure you actually want a server.. sure.
Linux, run the newest Ubuntu on new pc
or older on older pc, ive no idea at all what PC you have.
v72 old CRT , glass tube monitor a RELIC in today world.
why post OS questions lacking what HP computer you have of 1000s.
XP gone great idea, for sure....
OK F8 is Microsoft , for get them it not MS now, not at ALL.
in the Linux world its failing to find the correct minimum or
best resolution to match your old monitor
the monitor is year 2000.
the best resolution is 1024 x 768
you are using new linux, and it does not use that old old CRT
weak as a cat resolution,
you can use and older linux, or newer monitor
or change the resolution
using
if seen and done this 100s of time, endless,
btw your OLD CRT monitor does not use proper PnP plug and play
data comms.. its too old, why mess with CRTs in 2017?
walmart sells a $45 LCD , use that? and avoid darkages resolutions.
the way to do this is to run in command line mode
and change the config file, called, xorg.conf
https://techblissonline.com/ubuntu-804-set-default-resolution-1024-768-virtual-pc-2007/
there are other ways,
recompile the kernal to default to this reso? relic
or there is hot key at boot, read the manual on ubuntu
and change to lowest poor resolution
then run setups with a working desktop.
ask on a Ubuntu forum, it can vary by year, OS made and version
and what what desktop running of the many.
https://wiki.ubuntu.com/X/Config/Resolution#Resetting_an_out-of-range_resolution
keep in mind
your CRT is not supported now.
you must force it.
one more for V12, dropped the startup manager, wow....
best is to ask only for your version and choices at install time.
grub , KDE? what?
http://ubuntuguide.net/monitor-signal-out-of-range-problem-in-ubuntu-12-04-precise-fresh-installation
Jun 11, 2017 | HP V72 17" CRT Monitor
Setting the resolution lower
If it is a CRT you can'tset the resolution lower.
Dec 21, 2010 | HP V72 17" CRT Monitor
Monitor screen goes blue after game install.
You have an incompatability between the drivers and Windows. Uninstall the games. Is everything all right now? Upgade your video and sound drivers. You can download these from the manufacturers web site. Now reinstall the games.
Mar 21, 2009 | HP w2207 Monitor
Playstation 3 shuts down as game loads
Generally there are a couple of things that can cause this. Bad installs of games, and more commonly thermal damage. The bad news is it will probably have to be repaired and Sony generally charges about $150 for that. Hopefully its under warranty? =)
There is some talk that the new firmware download may have altered physical parts that control the temperature inside the unit. Although that's just heresay i've been hearing more and more people thinking this is the case.
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
When i start to play a game after 5 mins of playing,it will automatically shutdown the monitor
can u tell me wat games do you play?
and the system requirments of the game and specs of your pc.
Mar 06, 2008 | Smart Modular SV3170A
No signal
This sounds like your Video card might not be compatible with the game you are playing. You might need a better video card. Before you do anthing else, check to see if your computer is fast enough to play it.
Big games can crash slow computers, also it could just be a bad monitor.
Try checking the cord between the monitor and the computer.
Feb 23, 2008 | Acer AL1714 17" LCD Monitor
Power Saving Mode during game play only
I've got the same problem but it only occurs with one, older game.
I run a Radeon 8500.
Nov 03, 2006 | LG Flatron L1715S 17" LCD Monitor
HP V72 17" CRT Monitor Logo
56 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
