Question about GE Spacemaker JVM1640SJ Microwave Oven
The microwave is tripping the circuit and shutting it off.
    Champion:
  • 248 Answers
Could be short in microwave or bad breaker.I would try microwave on an outlet connected to a differant breaker first
Posted on Oct 12, 2010
Trips circuit breaker when not in use or when door is shut
There is a short to ground somewhere inside, in the electrics, possibly the magnetron filament. Take it to a competent service person, and do not mess with it yourself as microwaves have a very high voltage circuit inside which can kill you.
Aug 29, 2013 | Magic Chef MCD1311W 1.3 CUBIC-FT,...
Jenn air microwave quits working after 11-13 seconds of heating
open circuit switch when power reaches this switch it will shut down as switch is us
Aug 12, 2012 | Jenn-Air JMC8127DD Microwave Oven
When using the oven portion of the microwave oven it continues to trip the circuit the microwave is alone on a 20amp circuit .When I microwave it doesn't trip at all.Is it possible to move up to a 30 or 50...
If the breaker is an earth leakage type, it is possibly an earth leak problem which could be caused by insulation breakdown on the heater inside the microwave.
I would consult an aporved electrician for advice.
Jan 04, 2011 | Microwave Ovens
Went to warm up a food item and after 3 seconds the microwave shut off like the circuit breaker tripped. time face went blank, light inside does not light up and stove top lights do not light. circuit...
You have a fuse behind the screen panel. You have screws inside the microwave holding the panel. you have 1-2 at the bottom. You may also have to remove the vent. It has 2-3 screws which will be inside the vent. These can be removed from the front. Once these are removed the panel will pop off and you will see the fuse The fuse can be bought at a radio shack. BE SURE TO UNPLUG THE MICROWAVE! Good Luck
Dec 04, 2010 | GE JVM1631 Microwave Oven
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
Ge spacemaker microwave, new, keeps tripping the GFI but keeps running
The first thing you need to check is the GFI--when it trips, it definitely should shut off power to the circuit. It may be wired incorrectly, or is faulty. There should be a 20 amp breaker and wiring to the oven.It is also much better is the oven is the only appliance on this circuit. Hope this helps!
May 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The power cuts off after 2 minutes of cooking. The microwave doesnt turn back on for ten minutes.
There is an automatic circuit breaker that it tripping. One of two options
1) Something in your oven is either malfunctioning (difficult to find and replace). It is likely better to just replace than pay to have it fixed.
2) The house circuit that you are using is not providing enough power to the microwave. Check if something else is connected on the same circuit. A microwave runs poorly when not getting the full 115 volts that it was designed for and may fall into a safe mode and shut down for a while.
Newer houses should have the microwave on a dedicated circuit and should not have this problem - I say should not because electricians can make mistakes too.
You can try to trip your microwave circuit and see if anything else stops working. If so, that is likely why your microwave is falling into a safe mode - it is not getting enough juice.
If you have an older home (pre 1995), try to find what else is on your microwave circuit by tripping the breaker as listed above, then not using the other appliance when using the microwave.
Good luck.
Mar 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave / Frigidare PLMV
Chek the high voltage capacitor and the diode . If one of them are short there is a chance for tripping the breaker
May 25, 2009 | Frigidaire PLMV168 Microwave Oven
There is no power to the unit at all circuit breaker not tripped
blown fuse-easy fix -find book-it is shown behind service panel
Nov 04, 2008 | GE JVM1651 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
110 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
