Question about GE Refrigerators
Side by Side Coils
Where do I find the coils for cleaning on my GE Side by Side. Approximately 2001/2002 Model.
Everything sounds like it's running, but it's not getting cold enough inside. Some cold, but not much.
Clean the coils?
  • 770 Answers
Remove the toe kick at the bottom front open both doors and pull off if you dont see them there since i dont have a model # then you will need to rool the unit out from the wall unplug and reomve the bottom plate to get to them
Posted on May 31, 2008
How do I manually defrost the unit
Worst case to defrost, clean everything out food wise and unplug and leave doors open until it all melts. It sounds like the coils are dirty so the unit keeps running until it freezes over. Try cleaning all the coils, the compressor, etc, and when you try it make sure that there isn't anything in the way of the airstream
Jun 20, 2014 | GE Profile PSW26P Stainless Steel Side by...
I have a GE gsl25jfta bs side by side, the freezer melts ice box then freezes it again.. Making a block of ice
Sounds like you could have a bad mother board. Very common problem with the GE models. It will shut compressor off, than everything starts to melt, then it comes back on. Replace main control board and it should resolve your issue.
Jun 18, 2014 | Refrigerators
12 year old GE ref side by side both sides warm
has cleaning the condenser coils helped out? does the condenser have a fan? if so when the compressor is running it should be running also. is the compressor hot to touch?
May 20, 2014 | Refrigerators
GE Profile Arctica Model PSS25NGNA CC Hi, I noticed that water was leaking out of my water dispenser. Upon opening the freezer I noticed that everything was thawed out. The doors had been closed and t
you ended with the fan starts to run ? check the coils there should be a fan that blows across the coils sometimes the fan gets to dirty dusty clean that out and make sure that it works it must be running to keep the gases from over heating also clean the coils as will help big time
Oct 22, 2012 | Refrigerators
We have a GE Side by Side Profile refrigerator and the freezer, at it's highest setting, can't keep ice cream frozen and the ice maker only puts out about 8-10 dumps in a 24 hour period. The model is...
Sounds like your coils are dirty which will cause inadequate cooling due to reduced heat exchange at the coils. Also check to make sure fan is running (next to compressor and should be running when compressor runs). The fact that your ice maker makes ice at all suggests that compressor runs, therefor no freon problems. Problem should be easily fixed with correct diagnosis. Hope this helps.
Dec 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The middle black strip on my GE refrigerator is burning hot. Model # GSL25JFPE BS. What is this and how do I fix it?
this is the wall between the freezer and the frg i think . it is warm when the compressor is running . and if hot / then look under neath unit and i thing you will fing the coils ar very dirty or the fan is not going or both . so clean coils every 3 to 4 times a year and repl fan if it has failed . and things will get better .. ,mm
Aug 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My arctica side by side is running very cold...everything in frig is freezing, even when I turn up the temperature. The freezer, also, is running colder than zero. I've cleaned the back, coils, etc. and...
sounds like the controil board is locked in run
try unplugging it for about 10 minuts
if that does not work you will need service to properly dioagnos the control
the artica has had issues
hope this helps
Oct 13, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE side by side refrigerator, coils has ice accumulating on them. frig not cooling properly.
Make sure the fan is running. and if there is a fan on bottom at the back. where the compressor is
clean the coils where the compressor is. If this don't help or stop it. It may be low on freon.
Sep 20, 2009 | GE Refrigerators
Can't find refrigerator coils/ cooling issues
There're two coils ,the condenser coil wich you already clean (also make sure the condensing fan motor works properly and the fan blades are also clean).The other is the evaporator coil wich is located inside the freezer behind the back wall cover.
Apr 21, 2009 | Refrigerators
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
