Question about Jenn-Air JES9800BAS Electric Kitchen Range
Whirlpool/jenair oven #jes9750aaw
We received an error code f1-7 on our key pad on our oven. We had a service tech come to look at it and he said that the control pad needed to be replaced. He wanted to charge $525 just for the part so of course we didn't go for that. My husband found the part on line, replaced it and we are still receiving the same error code.
Can you please help us?
Kim
  • Chindo34 Apr 11, 2009
    I got this same F1-7, What part did you replace?? I have heard that its the clock assembly and they run about $260
5 Suggested Answers
  • 5 Answers
SOURCE: F7 Error Code reappearing ONLY when oven is
Once you price the circuit boards, you'll probably realize, you can buy almost an brand-new Kenmore for the price of these printed circuits. I'd suggest you do that and get a new warrantee instead of fixing these poorly-designed poorly made Jennairs.
Posted on Aug 31, 2009
SOURCE: Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
Posted on Nov 04, 2009
  • 1156 Answers
SOURCE: We received the F-7 error code. My husband
F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
According to the tech sheet inside the oven the F7 code is 'shorted matrix or start key' and could be due to a problems with the "key panel or control". But, these parts are in the $150 to $200 price range, plus the cost of a service call.
Also, just noticed, that the tech sheet gives instructions on how to read error codes stored in eeprom memory, that is, push timer, clock, and '9' together. When displayed push '8' and '6' to clear (hold them until it clears).
You can get parts from the below link:
http://www.appliancepartspros.com/partsearch/
hope it helped..
Posted on Jul 14, 2011
zeronullity
  • 71 Answers
SOURCE: Jgs8750ads I replaced the touch board and short sensor and still receive F3-1 code
Typically this code is cause by a bad thermal sensor or thermal fuse. Might want to check wiring for continuity, resistance, open shorts leading from the sensor to the control panel using a multimeter.
Posted on Nov 16, 2011
Whirlpool mircowave model MH3184XP the display reads F2
There is a problem with the control pad. The membrane, or surface, of the pad may be broken or damaged somewhere, resulting in the F2 error code. This is common for Whirlpool microwaves.
Press "Stop/Cancel" twice and select a new cook program. Press "Start" to begin.
If the error code persists, press "Stop/Cancel" again and unplug the microwave. Wait several minutes and plug it in. If the F2 code appears again, it requires repair.
Replacement membranes can be found online
http://www.appliancepartspros.com/whirlpool-panel-asy-control-8205376-ap3775860.html
but the internals of a microwave are dangerous, having high voltages even when unplugged. With the cost of parts and labour from a service tech, you may be best buying a new oven.
Sep 04, 2013 | Whirlpool MH3184XP Microwave Oven
Kitchenaid superba failure codes e1,f2, and door is locked
Hi Bill:
The E1F2 error code indicates replacing the board. It is in the realm of possibilities that your new board is defective. If I were certain the board was good I would focus my efforts on tracking down an electrical fault.
The likely failure is the control panel; however it could be the control board.
Since you did replace the control board already, the problem is most likley a key pad that is sticking.
I added a portion of the technical data sheet in the image below. You will need an ohm meter to be able to check the key pad operation. I added the information needed in the image below. If the control panel tests OK, replace the control board, if it fails, replace the control panel.You may need a hands on tech to run these tests and diagnose and repair your oven. Or just buy the key pad controls. Check THIS LINK.
Here are the parts
Replacement parts for WHIRLPOOL KEBS208DSS8 ' AppliancePartsPros.com
Here is a manual and a tech sheet
https://secured.whirlpool.com/Servic...all%20Oven.pdf
http://www.servicematters.com/docs/w...%204451879.pdf
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 20, 2011 | KitchenAid KEBC208 Electric Double Oven
Error codeE6 F2
Remove the power from the oven. Open the control panel and unplug the key pad ribbon from the control board. Assemble the control panel back and turn the power on. Wait a few hours.
If the error code came back on, replace the control board.
If the error code did not show up, replace the control panel (the key pad comes as a control panel assembly).
- The part number for the new control board AP3595759
- The part number for the black/stainless control panel AP3131755
Good luck.
Gene. __________________Hi I did some research for your oven and this is what i found , someone with the same problem , control board needs to be replaced , if you click on the web page below it will explain it to you , good luck Frank
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1094-whirlpool-fault-code-e6-f2.html#ixzz1gYuqvZnV
Dec 14, 2011 | Whirlpool RBD275PR Electric Double Oven
F24 error code
Hello there
  1. Turn the oven off and wait three minutes before turning it on again if "F -24" or "F-25" is displayed. These error codes mean the keys on the control panel were pushed or touched for longer than 60 seconds. Leaning against the oven or hanging objects in front of the controls can cause these error codes to appear.
  2. 3 Press the "Oven Off" key to clear the display and reset the oven if an "F" followed by two numbers is shown on the display. Wait three minutes, and turn the oven on. This type of error code indicates a problem with the signal received by the electronic control board.
  3. 4 Write the error code down if an error code displays more than once. Thermador recommends calling a service technician if an error code reappears.
Dec 04, 2010 | Whirlpool Kitchen Ranges
Good evening. Have a repair tech that cannot figure out problem and is trying to upsell to a new oven. We have a whirlpool rbs275pdb11 whirlpool oven that we replaced both the control board and the...
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%^*(
Aug 20, 2010 | Whirlpool RBS275PD Electric Single Oven
Error codes E1 F2 whirlpool super capacity 465 oven
HI. This code is a good indication of a separated key pad ribbon or the actual key pad may be damaged. Use the procedure below to isolate the culprit.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jul 25, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I have a Whirlpool model RBD275PDB12. I am
Hello,the error E6 and F2 you are receiving could be describe as "Cancel Key line open".Follow the following steps
1. Check keypad connector for firm connection(Keypad connection to control board).
2. Press CANCEL if error code returns after 60 seconds,replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replay control board (also called ERC or clock).
TThanks
Jun 03, 2010 | Whirlpool RBD275PD Electric Double Oven
Warning codes f2 & e3 on Whirlpool oven . Warning beeps alerted us to a problem.
good luck
Feb 27, 2010 | Whirlpool Ovens
Whirlpool RBD305PD has error F2E6 error on control panel
When this code appears and display is going blank too, it is always the control board. The only option is to buy a new one or get it repaired. It can be fixed quickly and reliably. www.fixyourboard.com
Apr 02, 2009 | Whirlpool RBD305PD Electric Double Oven
F2 E6 Codes appear, time flashes off and on
HI, this is a faulty key pad issue. check the following.
Mar 31, 2009 | Whirlpool RBD305PD Electric Double Oven
Jenn-Air JES9800BAS Electric Kitchen Range Logo
256 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
