Question about Whirlpool Washing Machines
Whirlpool washer aqua steam 6th sense put load on when time got to 1 minute left it got stuck left it for an hour but had to go to bed. Switched it off at mains as well as appliance off button and left for a while turned it back on and it was still locked but no longer saying that cycle with 1 minute left. I started a new cycle to let it finish all the way to open door and keeps getting stuck at 1 minute so now I still can't open door
dutchman05
  • 487 Answers
SOURCE: have just got new
Please register and forward this question to them
WHIRLPOOL
If this does not help you than Email direct whirlpool_customerexperience@whirlpool.com
If it is codes 32 it will be the pressure switch which is not working right
Posted on Jul 20, 2008
the dr
  • 447 Answers
SOURCE: control lock light
someone has enable the child lock feature. One of the buttons should say hold 3 secs for control lock under its normal function description. Hope this helps
Posted on Jan 01, 2008
jsrock516
  • 5911 Answers
SOURCE: help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
I hope this helps you. If you require additional assistance, please let me know.
Posted on Aug 27, 2008
  • 5 Answers
SOURCE: GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Posted on Sep 30, 2009
Whirlpool 6th sense fridge freezer instructions
unplugging the unit for 10 minutes is the reset feature. other wise I refer you to the owners manual
Dec 22, 2017 | Whirlpool Refrigerators
Whirlpool Cabrio washer stuck on sensing the load
Spring:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, Whirlpool_Reviews@Whirlpool.com, with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
Mar 08, 2018 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool aqua steam 6 door won't open tried resetting, cleaned out filter can you help ?
We had the same problem. Mechanic had to come and replace the lock. Took him less then three minutes to open the door, remove the old lock and put a new one in.
Jun 30, 2012 | Whirlpool AQUASTEAM 9559 WASHER FOR 220...
Whirlpool 6th sense stops at 1 min and doesn't finish wash cycle
We had same problem, and the only thing that we could do is call the repair man. He put in a new door lock and the problem was solved.
May 21, 2012 | Whirlpool AQUASTEAM 9559 WASHER FOR 220...
I have a whirlpool duet steam front loading washing machine model # WFW9600TA01. recently when my wife starts a load of laundry at night when she wakes up in the morning the washer is still turning at a...
I would assume the load in the washer is a small load and the washer has a difficult time adjusting the load to spin. I would push pause, wait for the system to unlock the washer. Check the load for how much water in the garments. If heavy, the unit has a unbalance issue, just try to continue the load. If the clothes are light than unload the washer into the dryer. Was the unit ran on delay? This may be a non issue if the unit ran on a delay and just never finished yet.
Give those a try and get back to me, I and interested in the status.
Aug 21, 2011 | Whirlpool Washing Machines
I have just bought a Whirlpool 6th sense 8kg load washer. It makes a clunking noise whilst washing and seems to be loud when spinning is this normal
have you been overloading the drum---thiscan put too much strain on the rear bearings---you willhave to replace the complete drum
Dec 07, 2010 | Whirlpool AWM6100 Front Load Washer
Its a whirlpool 6th sense washing machine no awd/d 5706, it stopped with a full load in 8 minutes before end time no numbers are flashing up but it wont do anything , i have opened the door took washing...
i have a whirpool 6th sense washing machine and it wont spin and the timer stays on 14 minutes remaining have you come across this problem and do you have a cure
Jul 29, 2010 | Whirlpool Washing Machines
One minute left
be sure water is draining out before spin starts if necessary remove bottom panel and clean pump out and ck hoses to pump be sure there are no excess suds ..wash only full loads small loads or loads with 1 heavy item will cause washer to sense off balance and try to balance load this will extend cycle time
Nov 09, 2008 | Whirlpool GHW9400 Front Load Washer
Whirlpool gold dishwasher gets stuck at 53 minutes left for an hour
Try "resetting" the control board by running the diagnostic cycle. The cycle completes in 15 minutes.
The details are in the service manual. The manual can be found hidden behind the tow plate (at the very bottom front of the washer).
The diagnostic cycle may tell you the problem. It also helps clear up some of the software gltiches.
It is easy to run the diagnostic cycle.
Just the buttons in the following sequence. The sequence should be complete within 6 sec.
heated dry -> Normal -> heated dry -> Normal
This will trigger diagnostic cycle of 19 intervals. Pay special attention to the intervals 18, 17, 9, 6, 4.
Interval 18 - displays your controller module number (should be letter 'd' followed by number 0 or 1 or 2 or something. Note that down for future reference.
Interval 17 displays 'software generation number' Note that down for future reference.
Then wait until you reach interval 9.  --- clean LED turns on - then an open or shorted thermister is detected.
-- Sanitized LED turns on - then the washer detected greater than 100 deg F temperature
Interval 7
-- Soaking/sensing LED should NOT come on (unless food soil is present).
Interval 4 -- Soaking/sensing LED should come on
Let the cycle complete and then try running the normal wash. Hopefully the possible glitches are cleared by now and you should have no problem.
If this doesn't work, time to call the expert tech.
Nov 08, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Washing Machines Logo
75 people viewed this question
Dan Webster
Dan Webster
Sal De
