Question about HP Computers & Internet
HP L1706 17" flat screen has failed to display anything.
  • 11,361 Answers
You need to check the power supply/inverter board caps, voltages, etc. I hope it isnot the lamp problem as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/HP%20L1706/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 11, 2010
My HP Compaq laptop nw9440 screen gives me white tin lines whenever I powered it on and don't display anything ,I tried removing the memory but still nothing happened
The memory has nothing to do with the display. Most likely it is the inverter board. For the display. They are not expensive an can be put in easily if you can solder. Take it to a repair place an let them look at it to make sure. I have seen the screen fail from crumbs an dirty contacts.
Jan 27, 2016 | HP Computers & Internet
I have an HP dv6707us laptop. The display started getting fuzzy and turning redish and would fail to display anything after a few minutes. I plugged in an external monitor and it works fine. I disassembled...
The screen replacement is defective or the part number is wrong, check the part number on the back of the original screen and compare it against the the one you replaced, it should match.
Jun 15, 2011 | HP Pavilion Dv6707us Entertainment...
Monitor went out and only displays a black screen. The power button indicates that the power is on but no picture. The model is an HP f1905 19 inch flat screen monitor.
Use a flashlight and shine on your screen. Look carefully is you still see the image on the screen. If you do, this is an indication that the monitor is still working, but the backlight has failed. A common solution with backlight-failures is to open the monitor, and look if you see any "swollen" capacitors (http://en.wikipedia.org/wiki/Capacitor_plague). If you see one you should replace it. Only open your monitor if you know what you're doing and have basic knowledge of electronics and soldering.
Mar 31, 2011 | HP f1905 19" Flat Panel LCD Monitor
Hp f1703 lcd monitor has no power at start up, bla...
guest, First thing to do will be to visit this web blog:
http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Do some reading to see if anything seems familiar to your problem of BLACK screen. If it helps you out a little then come back here and rate this response and tell us what action you will take to fix your unit. 12fixlouie
May 19, 2010 | HP Pavilion F1703 17" LCD Monitor
Have 10 Broken monitors with simalar problems. 1. Dell e153FPB- Video for 2 seconds than screen goes blank. 2. Dell e153FPB- After 20 mins, Display stops working. 3.Dell e1724FPB-Video for 2 Seconds than...
Pleasec look through my albums so you will know what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Dell bd: http://www.lcdrepair.us
Apr 24, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
LCD moniter locking up with blank screen. On/off button will not work
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 30, 2010 | HP w1907 LCD Monitor
HP L1720 flickering!
this is common, the display is bad.
all displays, fail. all do. no reason to get angry,
a broken display is worth nearly zero value $0
so how much money will you spend on worthless.?
you can get a new display at Walmart for $65, ,
lines are usually very serious. and is not ever the DC-DC inverter
a bad inverter (< it's power supply) is for the back ground lamps. not data side. the data side is failing and is common, if you twist the screen
it gets worse. ? bingo. data driver connections bad , screen.
IN most cases the part that is bad (screen), costs $100 new. or 50 used
why go there/
Jun 01, 2017 | HP L1720 17 in. Flat Panel LCD Monitor
My hp dv 6000 laptop with all power on fail to display.
Common problem.
There is a BGA chip that needs REFLOW.
Basically needs board service.
Mar 16, 2009 | HP Pavilion dv1000 Notebook
HP vs17e automatic auto-adjusts randomally.
well why not try the monitor on any other computer
if it fails there,
bingo bad monitor.
easy no?
that shifting is bad. real bad,
if the problem in only on your PC.
then the Video (card or GPU chip) is bad.
you never said what you are plugged into
1981 to 2017, 10,00000 systems. made.
Mar 17, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Computers & Internet Logo
105 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
