Question about Gateway FPD2275W LCD Monitor
Sony SDM-HS93 -No Power light, No Image
Hello, have a sony SDM-HS93 which does not give any indication of power - no LED light, no blank image, nothing. Checking the power input, the 5v and 12v volts are present, but not sure where to go from here.
  • 2 more comments
  • vandle Jul 29, 2008
    Exactly as above - sudden complete blank, black screen and no power light. Tested fuses and power lead to confirm power supply is OK, but no joy in getting the monitor to work. Tried with another old monitor to check it was not the output from the computer, but that works correctly. Is there a known power supply problem with these Sony monitors?
    randle.cowcher@googlemail.com
  • jamesnewton Aug 14, 2008
    Same problem.
  • Anonymous Sep 17, 2008
    have same problem. led is on for a bit then goes out. screen is all black no image
  • Seamonster01 Sep 27, 2008
    same problem!!
  • 43 Answers
It doesn't sound like an inverter problem if the fuse is OK, there should at least be a standby indication.
There are typical problems with ALL power supplies for LCD displays, not just these Sonys.
Posted on Feb 11, 2013
Sounds like an inverter problem.
Posted on Aug 29, 2008
Power light lights up but monitor dont come on
HI,Dear Friends..
Do you hear the hard drive working and see the LED flickering? As you can't see the screen to log on, Windows will stop at that point.
> If you have a spare PC monitor and VGA to VGA lead check it.
> And your keyboard working properly or not, if NUMLOCK light on it means your hard drive is OK.
> Your Monitor light on/off regular, or not? if light regular blink then power come but VGA section not working. So please contact Monitor Engineer.
Thanks...
Feb 13, 2013 | Sony SDM-HS93 19" LCD Monitor
My monitor flickered occasionally and one day went blank and turned off. It eventually came back on and then went back off another time. This happened more frequent and then went completely off and will...
Check the caps in the power supply first, hopefully it will not be bad lamp assembly as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
the HS-17 also has bad lamps problem.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 24, 2010 | Sony SDM HS93 19" LCD Monitor
Hi..my sony model sdm-hs93 lcd monitor flutters for a couple of seconds right before the screen blanks out. But, if I leave the monitor on for a day in sleep mode, the next day i can hook it up to the...
I think the problem with your monitor is that, the picture board on the monitor is malfunctioning that is why it keeps going blank after a minute.
What you need to do is to replace the picture board on your LCD monitor, replacing the picture board will solve the problem, because the picture board on the monitor at the moment is bad and will need to be replace.
Replace the picture board and you will see that the problem will not repeat itself again.
Take care.
Jul 16, 2010 | Sony SDM-HS93 19" LCD Monitor
Sony SDM HS73 ''turns off''
One thing I know for sure on this model HS73/HS93 is that the backlight assemblies failed due to poor soldering works. This may the problem with your monitor.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
It is very time consuming repair works that I doubt very much if repair shop will do the work.
Apr 19, 2010 | Computers & Internet
No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
Apr 18, 2010 | Sony SDM HS93 19" LCD Monitor
My sdm-hs73 moniter the power is on but screen is blank, what could be wrong
First check brightness and contrast settings.
If all good could either be your lcd back light has gone or the inverter. To check if its the black light shine a torch through the back of the screen to see if you can see a slight image on it, if you cant see anything the inverter board is faulty and to repair needs to be changed.
Jan 21, 2010 | Sony SDM-HS73P 17" LCD Monitor
Sony SDM HS93 works fine, but: Monitor will not turn on with power button, if I plug in A/C cord power light goes on, monitor works. Sometimes the monitor comes on too bright, other times, too dim....
i get same..controls not working ,,sometimes menu button works and one arrow button..button "ok" button doesnt work and up arrow...brightness not working.
i get black box in upper left corner...quite diffucult to get rid of.
G
iamthehipster@yahoo.com
Feb 25, 2008 | Sony SDM HS93 19" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
537 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
