Question about Kodak EasyShare LS753 Digital Camera
How do I solve the error E45 on a Kodak LS753 digital camera please
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 14, 2010
Kodak EasyShareLS753 screen has camera Error #E45 what is problem and how do I fix...turn the camera off and then on. if you encounter the same error, go to
Hello and Welcome to FixYa!
E45 error message sometimes means that the lens is misaligned, This error is also may be due to failure of the control system.
To solve this follow the given solution:
You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service center.
You must keep in mind that to open the camera without good experience is not recommended and might tamper the delicate unit so best option is to Contact Kodak to see if your camera is still under warranty, otherwise contact any Kodak Cameras service provider, your problem will be solved.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you for using FixYa!
May 09, 2011 | Kodak EasyShare LS753 Digital Camera
How do I fix error e45 for a kodak LS753
Error # 45 means the retractable lens is stuck, possibly caused by a drop or sand or other gunk that has jammed the gears. It will cost more to have repaired than the camera is worth, so you have nothing to loose by trying this. Hold the camera in your strong hand with the lens away from you and smack it hard into the palm of your other hand (if you can't take pain maybe use the heel of a shoe) pretty hard. It may take several tries. Best results - smack camera immediatly after turning off.
Oct 14, 2010 | Kodak EasyShare LS753 Digital Camera
Kodak easyshare ls753 error n e45
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 22, 2010 | Kodak EasyShare LS743 Digital Camera
Camera locked - camera error #E45
Hi
www.Kodak.com says:
"E45" appears on your camera's display when your camera requires service or repair.
I think it is a lens error. They have a page on www.kodak.com called Step-by-Step Solutions and Repair. This is for USA only.
See what they suggest.
I may be cheaper just to get a new camera.
Hope this helps.
Feb 21, 2010 | Kodak EasyShare LS753 Digital Camera
E45 Error
turn the camera off and then on. if you encounter the same error, go to www.kodak.com/go/itg to either avail of the service upgrade program or get it repaired.
Apr 11, 2009 | Kodak EasyShare LS753 Digital Camera
Kodak easyshare E45
the lens alignment of your camera is messed up it will take service repair to fix it, it would cost you the same for a new one...
however there is an alternative solution but this seems weird it up for you to try...
try to slap your camera several times on the side of the lens or try to intentionally drop it but not to hard, drop it on a carpet or somwhere thats not hard..
google this: error 45 on kodak easyshare LS753
then choose the 5th result youll find forum about this wierd solution...
Thanks! and good luck!
Aug 10, 2008 | Kodak EasyShare LS753 Digital Camera
Camera error message #E45 camera Kodak easy share cx6330
I have fixed the problem! For any out there with a the same problem, all you have to do is smack the extended lense against your palm firmly then turn the camera back on. It just worked for me and no more error, camera is now working fine. Good luck!!
Jul 14, 2008 | Kodak EasyShare LS753 Digital Camera
Screen says error#e45
mine says the same thing can anyone help? manzanero26 is my y
Jun 04, 2008 | Kodak EasyShare LS753 Digital Camera
Lens is stuck out
push up on the inner lens housing,
Dec 24, 2006 | Kodak EasyShare LS753 Digital Camera
Kodak EasyShare LS753 Digital Camera Logo
75 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
