Question about GE Profile 30" Self-Cleaning Freestanding Double Oven Gas Range - Stainless-Steel
Why is my flame showing yellow when oven is on and makes a slight popping sound when flame reignites. The top burners have a nice blue flame
  • 1 more comment
  • lf04259 Oct 11, 2010
    is this condition dangerous? Will I beable to clean my oven without worrying about an explosion? I have been baking and noticed this the other nite, is it ok to bake with the flame yellow like that?
    I don't know what this response means, as long as main valve is shut off gas entering kitchen. My question is can I use the self cleaning of the oven and can I bake in the oven with the yellow flame showing?? Also contacting the technical staff of the mark, who would that be? I am confused by your use of different wording.
    I am concerned that I will have a gas explosion and don't understand what he is telling me. Just makes no sense.
If your oven fails to light immediately after the gas builds up then you will need to replace the oven's defective igniter
Posted on Oct 11, 2010
  • 17,970 Answers
Likely, the gas is brought from the burner valve to the burner through a venturi tube. The burner control knobs that you see on the control panel attach directly to the burner valve. This valve controls how much gas is sent to the burner. To get a larger flame, you send more gas to the burner. The venturi tube between the burner valve and the burner allows the gas to properly mix with air for clean combustion. The air and gas mix then flows into the burner where the pilot flame or ignitor ignites it. On models with a spark ignition, there is usually a spark switch attached to the burner valve, a spark module and the spark ignitor. When you turn the valve, the switch tells the spark module to send electricity to the spark ignitor to create the spark to ignite the gas. Almost all older cooktops with unsealed burner units allow you to raise the entire top for cleaning and service.
Sound like any bad valve or clogged tube; check here to know how this works: how-bake-valve-works-C21.
Hope helps.
  • 2 more comments
  • ZJ Limited
    ZJ Limited Oct 11, 2010
    This may be due to the air/gas mixture being incorrect, the appliance may have been improperly converted. A flame is burning gas, but the flame may be colorless or yellow. For
    illuminating purposes a yellow flame is desirable, because the glowing
    particles of carbon in the flame give off light. But for cooking, a flame as nearly colorless as may be, is best. This is not only
    because such a flame is hotter, but because the other flame will deposit
    soot; and unburned soot on the saucepans means wasted fuel as well as extra trouble in washing. Air admitted to the gas furnishes
    an amount of oxygen sufficient to burn up the soot.
    When a gas stove is
    first installed, the plumber making the connection regulates, by means
    of a small valve in each, the amount of air necessary for each burner.
    This may need to be changed later if conditions change; but usually any
    change in the flame, particularly a sudden one, means that the burner
    has become clogged, perhaps by something spilled over it. In this case,
    if it does not readily burn clear again, the burner should be detached
    and boiled out in a weak solution of washing soda.
  • ZJ Limited
    Cleaning tasks can be performed without any fear, so long as the main valve is shut off gas entering the kitchen. If the situation happens again, I suggest contacting the technical staff of the mark, in order that the task is more thorough cleaning or to determine the change of damaged parts.
  • ZJ Limited
  • ZJ Limited
    If the first self-cleaning work wont work, I suggtes call technical service. This is my comments.
Whirlpool model SF3020EKQ3 was converted to LP oven lights nice blue flame but flame is very small oven does not get hot enough
HI,
If your able to adjust the orifice hood to the oven, then turn it counterclockwise unit the burner is full and minimal yellow flickering is present. If you go too much, this can be deadly can cause carbon monoxide to admit into the kitchen during use. I have found adjusting while the burner is on is the easiest way to make sure it is correct, use caution....
I hope this helps
Jul 23, 2011 | Microwave Ovens
The furnace turns on but cool air is blowing through the vents
When your furnace comes on have you checked to see what type of flame you have on the burners .They should have nice sharp arrow shape being mostly brite blue with a small amount of yellow,also flame should be setting on top of burners and not floating. If flame quality is not good then shut heater down and allow time for it to cool. Most burners can be easily removed by pushing forward on burner and lifting front end up slightly.Then move burner to clear orifice and remove. You can very lightly tap front end of burner on wood or some other material to loosen rust dirt or other material from top of burner. Lightly brush burner opening with soft wire brush and dump or blow out . Do one burner at a time replacing them as you go.
If I can be of more help to you please give me more information as to type and age of unit. Thank you
Dec 12, 2010 | Heating & Cooling
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
Large yellow flames after the oven is on and getting up temp
The needle maybe damaged or missing inside of the hood, unscrew the hood and remove it, look at the needle and make sure it is intact, put a little liquid soap into the hood threads and screw it back on until it bottoms out, it will be much easier to feel it bottoming out if it has lube on it, if this does not work, call them and have them send you a LP specific hood rather than the adjustable type.
Jun 13, 2009 | General Electric PGS975SEMSS 30 in. Gas...
GE PGB975SEMSS Broiler and Oven flames too large and yellow
It sounds like your not getting enough air mixed in with the gas.if you can't adjust for more air make sure you were not supposed to change the spuds that feed the gas on the lower units.
Mar 16, 2009 | Ovens
Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Nov 14, 2008 | Whirlpool SF325 Gas Kitchen Range
Wolf oven - oven clicks continuously
This sounds like you have a flame switch getting ready to go out. The reason you are hearing the ticking noise is that after the ignition is satisfied the flame switch is not detecting and sending a signal to continue to try for ignition.
Nov 02, 2008 | Ovens
The burners in the gas oven are producing uneven flames and creating soot - ie. blackening the doors and walls of the oven? There seems to be one screw on the left hand side of the burner - can we take the...
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Yellow flame and black soot is an indicator that the flame tube is being starved for oxygen. Where the orifice injects the fuel at the base of the flame tube you should find a movable air adjustment shutter that is usually held in position by 1 screw. This screw may have loosened and allowed the shutter to close off oxygen to the flame. Below is a link to a page that shows an oven burner tube...click to enlarge image pn1015233 and observe bottom end. Rotate shutter any direction until a nice blue flame appears but is not "blowing" off the burner tube. Tighten screw to retain position.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1015233&PPStack=1
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 05, 2008 | Kitchen Ranges
GE Profile 30" Self-Cleaning Freestanding Double Oven Gas Range - Stainless-Steel Logo
147 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
