Question about Canon CLC 1150 Color Copier
Error code E 020 0181 How do I clear error code? Cannon 1150 color laser copier
  • 4,323 Answers
Hi
Error code E 020 0181 means that the patch sensor has turned bad or is dirty, to access this try removing eac dev unit and gently unscrew each top so that the patch sensor window is visible. Also, check whether the toner hopper is overfull, it happens sometimes that the toner motor worm gear splits as a result of the hopper becoming packed tight. This may cause the worm gear to split and break if the hopper is 1/2 full or less. You may need to replace toner motor, part number (FH7-1762-030). If the toner motor is fine, then check whether the web solenoid is activating. Clean the web solenoid and ensure free action. This would clear error E020. If the error still not disappears then make sure that the DC controller is fine and the connections from the controller are fine.
Hope this helps...
Daniel
Posted on Oct 11, 2010
Error code e190 0000
Cause:
· The laser controller PCB is faulty.
· The CPU PCB is faulty.
Timing of detection:
An error has occurred while wiring
data to the laser controller PCB from
the CPU PCB at power-on.
Jan 25, 2011 | Canon CLC 1150 Color Copier
My canon clc 1150 is continously showing e 804 ?
• The operation of a fan (indicated
by detail code) is faulty.
• The CPU PCB is faulty.
• The DC driver PCB is faulty.
0001 The electrical unit fan (FM8)
has stopped to rotate in error.
0002 The IP cooling fan (FM7) has
0003 The exhaust fan (FM2) has
0004 The ozone suction fan (FM5)
0005 The toner suction fan (FM6)
0006 The laser scanner motor
cooling fan (FM4) has
0008 The primary charging
assembly fan (FM3) has
Aug 02, 2010 | Canon CLC 1150 Color Copier
E008 0000 Error on Cannon 1150
The problem is somewheare in fixing pcbs.
Probable causes:
• The fixing oil pump driver PCB is
faulty.
Try to reconnect all connectors on these pcbs.Or start to swap them from one to another copier, until you discover the cause.
Jul 07, 2010 | Canon CLC 1150 Color Copier
CLC 1150 Color Coiper E020 0142 What does this
Toner feed error, possibly clogged up in a feed tube, or in between hopper and developer.
Will most likely need a service technician to fix.
Dec 04, 2009 | Canon CLC 1150 Color Copier
CLC 1180 gives the error code E804 000B and instructs me to turn the unit off and on again. Once this step is completed, it reoccurs.
E804 0006 The laser scanner motor
There is no 000B in the manual....so I assumed it was a six.
The sub codes possible are 0001, 0002, 0003, 0004, 0005, 0006, 0007 and 0008. They all pertain to cooling fan failures.
Oct 19, 2009 | Canon CLC 1150 Color Copier
I own a Canon Laser Color Copier Model No. 1150 CLC1150. The error code when I start up the copier is E0000 0132. How can I fix this issue?
E0000-0132
the cause of error is the fixing heater/s is not functioning well .Try this press asterisk with the head then 2 and 8 simultaneously then same asterisk with head. The lcd display will change Pres the ff: COPIER>Function>Clear>Err > ok .to reset fixing error .Switch power off and on the machine.If the Error
return, you have to call the canon service agent to check your fixing/fusing unit and its components
regards
Jun 21, 2009 | Canon CLC 1150 Color Copier
E005 0100 Error
asfter clearing the error code turn the machine off then on again, if that dosen work remove the web then clear cut off turn on
Nov 25, 2008 | Canon CLC 1150 Color Copier
ERROR CODE
there is a problem with the fuser, replace thermistor or thermofuse
Aug 29, 2008 | Canon CLC 1150 Color Copier
Cannon 1150
Get in the service menu, press * 2 8 *, choose COUNTER, reset all counters to 0, go to FUNCTION/ CLR/ ERR, press OK. Turn off the machine and then on.
Apr 11, 2008 | Canon CLC 1150 Color Copier
Clc 1150 error 350
Normally only the canon service center will tel you what the error codes means. Suggest you call them .
May 18, 2007 | Canon CLC 1150 Color Copier
Canon CLC 1150 Color Copier Logo
647 people viewed this question
old marine
old marine
