Question about Garden
The primer bulb is stuck inward on a briggs and stratton 3.5hp classic
5 Suggested Answers
  • 61 Answers
SOURCE: 5hp briggs & Stratton lawnmower
ck fuel pump its on the side of the carb
3or4 screws hold cover on .
Posted on Sep 06, 2009
mowerman1857
  • 389 Answers
SOURCE: How do you remove the primer bulb on a model
Look at the outside of the plastic housing where the primer bulb is inserted, you will see an open area where there are 2 tabs, one on each side, using a small screwdriver, push these tabs inward to release them and slide the whole thing out of the hole including the primer bulb. The new primer bulb normally comes with a new mounting ring if you purchase it from a lawnmower dealer
Posted on Oct 01, 2009
  • 640 Answers
SOURCE: The red primer bulb is
If you are unable to pull it out, then you are going to have to replace it. Thankfully this is not too difficult of a task.
Posted on Jul 27, 2011
richroth
  • 9472 Answers
SOURCE: I have a Ryobi 6.5
What is your engine model number? It should be on a plate on the side of the engine. Your problem is a clogged jet inside the carburetor. Once I have the engine model number, I will be able to give you a carburetor diagram that will show you how to clean it.
Richard
Posted on Aug 18, 2011
Fuel leaks out of the primer bulb has a nipple with small hole. fuel coming out of the nipple hole. No breaks or tears in the bulb.
ethanol additive in gasoline causes deterioration of fuel system parts, especially primer bulbs. Needs to be replaced...relatively easy for mechanically minded or bring to dealer. Check Amazon for parts...they are cheaper than most dealerships.
Hope this helps....
May 01, 2016 | Briggs & Stratton Briggs Stratton...
The red primer bulb is stuck in on my 3.5 hp classic briggs and stratton vertical shaft mower. I've been starting it by simply pouring a little gas into the carburetor. What is the fix?
Jul 27, 2011 | Garden
Otmail.com Buble thing at carburator has stuck in and will not come back out any advice
I believe that your question is in reference to the primer button on your carburator. If this is so and your button is pushed in then you will have to change the button. Take a pair of needlenose pliers and pull out the damaged primer bulb. Then go in with a pick tool and pull out the ring that is seated in the carburator at the bottom of the primer bulb. With the old primer bulb out of the carburator you can now install the new primer bulb. Put new primer bulb into place and with a dull punch slowly and very carefully seat the new primer bulb. This should put you back in business again. GOOD LUCK.
Jul 05, 2011 | Briggs & Stratton Garden
I can't start my powerwasher. Where is the choke?
This Power washer has a 3.75 hp Briggs and Stratton Engine. It does not have a choke but does have a primer bulb. You must depress the primer bulb at least 3 times to start the engine. The primer bulb is on the side of the carb. It can be black or red. If your still unable to locate the primer bulb please provide your ENGINE model number and I will provide you a link to a diagram for the location of the primer bulb.
Thanks for using FixYa.
Kelly
May 29, 2010 | Briggs & Stratton Gas Pressure Washer...
Where is the check valve in the carburetor on a Briggs & Stratton
I believe you have to remove the primer bulb and it is located behind it. Be careful and do not damage the keeper or the primer bulb there is a couple of notches on keeper to depress to remove,
Sep 20, 2017 | Craftsman Garden
How do you remove the primer bulb on a Briggs and Stratton model 10a902 engine
On each side of the primer 'casing', there are apatures in the outer. Squeeze these inwards, and the retaining ring and primer rubber can be pulled out.
Sep 27, 2009 | Garden
How do you remove the primer bulb on a model 10a902 Briggs and Stratton mower engine?
Sep 27, 2009 | Briggs & Stratton Garden
Garden Logo
1,145 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
