Question about Kenmore 43042 Front Load Washer
I currently have a Kenmore front Load Washer 43042 that was left by the previous owners. I do not have the manual for this but here is my problem. When I put fabric softner in the dispenser let the washer run a full cycle and open up the dispenser in the spot where the fabric softner went it is filled with water that does not drian out. What would be the problem??
  • melfran2002 Oct 11, 2010
    i removed the access cover but i am not sure what hose you are referring to? There is a larger hose that loks like it goes directly to the washer tub??
    Thank you very much
  • 2,382 Answers
Hi, you have a problem with the drain and this is how to fix it. Remove the bottom panel under the door to access the drain pump. Make sure the washer is unplugged before servicing the pump. The pump will be located under the wash tub in the front of the washer. There should be a small access cover that can be unscrewed to access the inside of the pump. If not, remove the inlet hose to access the pump impeller. HINT: Pull the drain hose from the standpipe and use a shop vac to pull a vacuum on the drain line. This will pull any remaining water out of the drain lines and wash tub. This will minimize the amount of water that spills out of the drain pump when you remove the access cover.
It does not take much to damage this small drain pumps. If you clean the pump thoroughly and it still exhibits drain problems, the manufacturer recommends replacing the pump.
Posted on Oct 11, 2010
  • Tunde Autos
    Tunde Autos Oct 11, 2010
    Yes, it is the hose that goes into the washer tub
205850 model motor
My kenwood 43042 front load wash machine will not spin out and the motor smell like it burning. I just installed a new motor
Jul 12, 2013 | Kenmore 43042 Front Load Washer
My Kenmore Front Loader washer machine is making a loud noise during the spin cycle
tub bearing more than likely.tub has a 10 yr warranty so call sears get the flat rate labor charge their offering then have them replace the tub
Jan 11, 2010 | Kenmore 43042 Front Load Washer
Kenmore 43042 front loader, black boot (?) twisted and loose
the black gasget on the inside of the door is suppose to be loose and flexible for sealing purposes.
when your washer went thru it's spin cycle is it possible the throw pillow got cought between gasget and wetal tub?
also is this the only time you noticed this ?
Oct 01, 2009 | Kenmore 46462 Front Load Washer
Washer is louder than normal The drum seems to
the bearing assembly is beginning to fail.
requires an overhaul.
this problem is far too common with Kenmore and frigidaire front loaders
Mar 24, 2009 | Kenmore 43042 Front Load Washer
What all is needed to stack my kenmore h3 front loading washer and dryer
a stack kit, check sears and the instructons should be in the kit
Jan 29, 2009 | Kenmore 43042 Front Load Washer
Kenmore front load washer 417-44082400
My kenmore front load did that just a few months after I bought it. Unfortunately it was the the electronic board {brains of cycles} that had to be replaced. Had to replace it 3 times!! Warranty did cover it. Look into your warranty--at that time the boards were $200-$250 each!!
May 13, 2008 | Kenmore 43042 Front Load Washer
Water leaking on floor after every wash
there should be an acess panel that your husband can remove(2 screws on either side of bottom of panel. From there you will get a bettter idea of where leak is coming from. might be as simple as a hole in a drain line. take a look
Mar 08, 2008 | Kenmore 43042 Front Load Washer
Kenmore Front load Belt problem
can your retighten it ,,w / cresent wrench if not bearing is probably shot check for any leaks
Oct 17, 2007 | Kenmore 43042 Front Load Washer
Can I stack my Kenmore washer (front loader) and dryer?
They can be stacked, but you will have to purchase a special kit to do it. Sears should be able to order the kit for you. Without the kit, when the washer goes into spin, the dryer will fall off (not good at all). Good Luck!!! Jim
Sep 05, 2007 | Kenmore 43042 Front Load Washer
Kenmore 43042 Front Load Washer Logo
131 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
