Question about Toshiba Satellite A135 Notebook
Toshiba Satellite Problem
Hi! My Toshiba Satellite randomly shuts down and mouse freezes.
  • 4,234 Answers
Keep track of when the laptop does this. If it gets too hot, this will occur as well. Check to make sure that the cooling fan starts up. If heat is the problem, I would expect thi problem to show up after it has bee booted for a while.
Posted on Jun 09, 2008
  • 3,422 Answers
Start your toshiba in the safe mode and run a virus scan.There must be a spyware which is causing this problem..\
Posted on Jun 01, 2008
My toshiba satellite series keeps freezing up when idle and I have to do a force shut done, any suggestions?
Best suggestion is to back up your files and reinstall the OS.
If it freezes while idle, some necessary data is most likely corrupted.
Force shut downs often cause system files to corrupt.
Oct 18, 2012 | Toshiba Satellite L305-S5908 Notebook
The case is: I shut my laptop " satellite a300 Toshiba" off by the button, and I did not wait it until shut down normally. then, every time I try to turn it on again it starts normally and...
That pointer is there to notify you that no operating system was found - Windows has been completely corrupted when you have shut it down while it was still working. Just reinstall it and all will be back to normal.
May 18, 2011 | Toshiba Satellite A300-ST6511 Notebook
Toshiba satellite L505D GS6000 mouse freezing
reinstall the driver for the mouse touchpad
Feb 22, 2010 | Toshiba Satellite A60 Notebook
Toshiba satellite P15-S420 odd power & freezing problems
  1. Click Start and then Control Panel.
  2. If you're in Category view, click Performance and Maintenance.
  3. Then click on Power Options.
    If you're in Classic view, double-click on Power Options.
  4. Click the Hibernate tab.
  5. The Enable Hibernation box should be unchecked.
  6. Click Apply.
  7. Click the Power Schemes tab.
  8. In the Plugged in column, from System Standby option, set a time out period.
  9. Click Apply.
  10. You can adjust the Turn off monitor and Turn off hard disks settings as well.
  11. Click Apply. Click OK. Close the control panel.
This is what you should see
Please rate this a fixya
Feb 09, 2009 | Toshiba Satellite P15-S420 Notebook
Toshiba satellite m40 booting problem.
Hi! It appears that possibly your hrad drive isn't set properly in the caddy? with the laptop powered down and disconnected locate the hard drive cover pop out the two locating screws and carefully move the caddy/hard drive BEWARE as the drive has fragile pins at the opposite end where you opened, hopefully little sliding pressure should remove. Check the retaining screws around the caddy (You'll need a small torx/philips screw driver for this) if all tight replace gently.
If you are uncertain I would recommend a technician check it for you.
Good Luck!
Paul 'W'
Dec 09, 2008 | Toshiba Satellite M40-S417TD Notebook
Satellite Pro "Locks up"
the first step would be to obtain a memory checking program to check the ram,
windows can help with that free,as i think it may be your problem.
good luck
Mar 27, 2008 | Computers & Internet
Random screen freeze
You are going to need your WINDOWS CD:
Dec 03, 2007 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite A135 Notebook Logo
115 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
