Question about HP LaserJet 1160 Printer
Shadow prints in the left side of the paper - HP LaserJet 1160 Printer
    Scholar:
  • 107 Answers
Hello, if you already changed toner cartridge, and problem is still there, the fuser unit will need to be serviced or replaced.
Posted on Oct 11, 2010
jaylex
  • 417 Answers
SOURCE: Printer only prints on the left side and wrinkles up the paper on the left side
Hi there it could be that the fuser or the drum unit has some sticky labels attached to it check these units also check the paper feed path as there may also be some obstruction causing the paper to crease and crinkle.
Hope I could help
Thanks J
Posted on Jan 19, 2008
pdouglasss
  • 125 Answers
SOURCE: hp laser jet 2430 dtn prints lines on left side of paper
Hi Karent503:
It sounds like you fuser assembly is worn. The part on the fuser assembly that you are having a problem with is the heat roller assembly located in the fuser. You can have a technician replace that for you at you local HP repair center, Her is the part number for the fuser assembly.
Fuser, 110-127 V RM1-1401-000CN
Posted on Apr 03, 2009
SOURCE: Paper wrinkles on left side when printing
It is the fuser film. Most of these printers will have this problem at about 30,000 printed pages (a relatively small number compared to the 300,000 pages the printer is supposed to last according to HP). The fuser film starts to slide to the right and it starts getting ripped by the gears inside.
The only thing you can do is replace the whole fuser inside (probably the easiest solution), or try replacing the fuser film. You can search online for a fixing kit that comes with the fuser film and the grease needed for about $35.
Hope this helps, best regards.
Posted on Jun 29, 2009
pineworks
  • 4041 Answers
SOURCE: Starts to print but jams on left side.
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 16, 2010
  • 21 Answers
SOURCE: why is there a shadow
Hi
1. Toner might be running out
2. How to clean drum unit? http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002200/000056/faq002256_004.html?reg=eu&c=eu_ot&lang=en&prod=mfc7840w_all&Cat=112
3. Scratch or dirt on heat roller (at the back of the machine).
regards
Posted on Feb 15, 2011
HP LaserJet 4Plus - just changed the fuser and rollers - was getting smudges and shadow on the printer paper. Now getting (on the left 1/4th of the page) light areas with little or no print. The shadow...
Take the toner cartridge out of the printer. Shake it side to side. Reinstall it and print something.
See if that fixes the output.
Could also be the transfer roller.
Jun 28, 2011 | HP LaserJet 4 plus Printer
I have an hp2430, it is pringinting shadows along the left edge of the papers and a line along the right side. I have printed a cleaning page 3 times and replaced the cartridge, running the cleaning page...
the line could be caused by a scratched DRUM unit or a contaminated trasfer roller... And the shadow is probably a broken MICA ROLLER in the FUSER,
To get rid of the line (if the drum is OK) you need a mantenance KIT for that model, (pickup roller, transfer roller, separating pads etc...), for the shadow you need a new FUSER
Cheers!
Mar 22, 2011 | HP LaserJet 2420 Printer
Canon LBP5000. The printer has stated to print a shadow image of the darker parts of the print. Not always from the start but after some prints. The shasow image can also be from the previous print. It is...
Had the same problem with LBP5000. Used the Cleaning Utility(Options/Cleaning) in the printer software, had to run it several times, the shadow did not go away the first time. Looks all right now.
Hope this helps.
Thor.
Nov 08, 2010 | Office Equipment & Supplies
Hi My printer 2600n prints a shadow of the
if logo preprinted may not take heat if everything repeats check fuser
Jul 28, 2010 | HP Color LaserJet 2600n Printer
Hi, the trouble with my hp 1022 is when i print something, in the printed paper appears a shadow from the original text. can you help me. thanks
use plane paper of 60-80 gsm if your printed paper is offset/screen print it will repeat and shadow appears because of high temprature in fussing unit.
Feb 03, 2010 | HP LaserJet 1022 Printer
There is a faint background shadow covering the
remove toner/drum unit from the printer. remove toner from drum unit and shake toner cart. side-side to loosen toner inside. On top front of the drum unit there is a purple/blue button that will slide right-left. Do this a few times to clean the wire. If there's a lot of loose toner, take a vacuum and clean carefully. Put everything back inside. With front door still open, hold GO/Control button down until all lights have lit, then let go, close front cover.
If you still have the shadow over the page, it's most likely the toner cart and you need to buy a new one (or recond.-refill) at someplace like Office Depot or Staples.
Jan 20, 2010 | Brother HL-2040 Laser Printer
Hp laser jet 2430 dtn prints lines on left side of paper
Hi Karent503:
Apr 02, 2009 | HP LaserJet 2430dtn Printer
Dell 924 All-In-One printer
Below are the various sizes and types of paper supported by your printer. Make sure you donnot load the tray beyond the maximum limit , otherwise the rollers may not pull the paper correctly
• Letter*
• Legal
• B5
• A4
• A5
• 3x6
• 4x6
• L
• 2L
• 5x7
• Hagaki
• 10x15 cm
• 13x18 cm
25 greeting cards,
index cards,
postcards, or photo
cards
• The print side of the cards faces up.
• The cards are centered on the paper support, in between the left and right
paper guides.
• The paper guide rests against the left edge of the cards.
• You select Normal or Photo print quality.
25 sheets of photo
or glossy paper
• The glossy side of the paper faces up.
• The paper is centered on the paper support, in between the left and right
paper guides.
• The paper is loaded vertically against the right side of the paper support.
10 iron-on transfers • You follow the loading instructions on the packaging.
• The blank side of the transfer faces up.
• The transfer is centered on the paper support, in between the left and right
paper guides.
NOTE: For best results, iron-on transfers should be fed one sheet at a time.
50 transparencies • The rough side of the transparencies faces up.
• The transparencies are centered on the paper support, in between the left and
right paper guides.
NOTE: You can load a single transparency into the paper support without
removing plain paper.
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
Weird toner issues
Hi Kelli.i would replace the drum unitand toner!
Mar 31, 2008 | HP LaserJet 2420dn Printer
HP LaserJet 1160 Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
