Question about Car Audio & Video
Stereo sounds great but CDs do not want to eject. So far, they have ejected eventually, but I am afraid it is going to get stuck for good.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
What model radio is it? you may have a dirty pinch roller. sometimes you can get by with cleaning it with a qtip. make sure the qtip doesn't get sucked into the cd mech.
Posted on Oct 11, 2010
CDs stuck in stereo system
Have to take out the mechanism from the set, to eject the disc. For some sets, there will be a trick to take out the disc in emergency. Contact any service technician.
If you wish to get details about, how to take disc in emergecy, visit these sites.
Type in this key phrase "how to take disc in emergency" in the search box of the site, at the top right side of the display window, to get gathered the related posts.
http://electro-medical.blogspot.com/
Feb 29, 2016 | Audio Players & Recorders
How can I eject stuck CDs from CD player 2006 toyota camry grande?
Isn't there a security code needed to reset the stereo after a battery change? The Stereo thinks it has been stolen. See your Manual and see your nearest Toyota dealer. Or use a tweezers to reach in and pull out the stuck CD. And clean the rollers with alcohol.
Dec 29, 2014 | 2006 Toyota Camry
I replaced my ignition switch in my 98 k2 jetta and after my stereo won't turn on but will eject cds and insert them?
The red wire from the stereo is 12v signal, basically when you turn the key on it send 12v to the red wire to make your stereo come on. Everything else is fine since you can insert and eject cds. You may have pulled the signal wire loose when you changed the ignition switch, check the wires behind the radio and the wires to the ignition switch.
Dec 11, 2013 | Bosch 1998 Volkswagen Jetta K2 2.0L...
How do i eject a cd from the JVC KD G510 car stereo. A CD is already in there but i can't figure out how to get it out and put a new one in
A malfunctioning stereo may least allow feature buttons to perform extractions of CDs. Depending on how the stereo was installed, the car would have to be powered on to attain stereo functionalities. Second, CDs have to be inserted with the readable media side facing the appropriate lenses to achieve results. A wrong insertion of the CD into stereo compartment may require forceful extraction. Observe the type of stereo to ascertain CD extraction also known as reset buttons. Usually a tiny area, the reset button allows inserting an object that forces the car stereo to eject stuck disks. Every mean to eject stereo disk have to be performed while the car is turned on to utilize the source of power. An unsuccessful attempt to dislodge CDs in stereo compartments would require auto electrician's consultation. An unsuccessful dislodge attempt usually requires acquiring a new stereo in replacement of the malfunction.
Feb 02, 2011 | JVC KD-G510 CD Player
Jammed cds in my RX 330
I also have a 2005 Lexus RX 330. Hold down the eject button with the car on. When you completly turn off the car the cd's should eject. You may have to do this a few times before it works. I also had this same problem with my 2003 Honda Accord. I clean the cd player regularly but I have found that it does not always eliminate the cd errors. I purchased a cassette adapter for my I pod for $12.99 and have been happy and error free ever since! Good Luck
Jul 15, 2010 | 2005 Lexus RX330
The cd will not work just ejects disc ?
if it does this with all your cds then your better off to just buy a new stereo. if your cds are burnt cd's it may not read them
May 10, 2010 | JVC KD-SX840 CD Player
2004 Chevy Silverado factory Stereo, CD is stuck in player, sounds like it is trying to eject but won't!
I searched quick and couldn't really find anything on a manual eject button. Flip through the manual a little bit and see what it has about the radio. If all else fails and you aren't worried about possibly breaking the stock cd player, some skinny needle nose pliers should reach in far enough to grip the cd and you can pull it out. But there is a good chance you could break the cd player in doing so.
May 04, 2009 | 2004 Chevrolet Silverado 2500HD
Onkyo c707chx...
This is an easy fix if you are somewhat handy.... The belt for the door/tray is slipping. If you remove the enclosure and face plate, you will see two motors below the disc drive. Press eject while observing the pulley to the left. You should see the problem with the motor shaft spinning and the belt slipping. Replacing the belt is possible without any further dissassembly. Simply bend some light wire into an L shape and you should be able to hook both pulleys and lace the new belt on. As far as obtaining a new belt I decided to do the simple thing and use a slightly smaller rubber band. The repair has held now for almost three months and the player is used everyday. Good luck.
Jun 21, 2008 | Onkyo MC35Tech CD Shelf System
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
