Question about Craftsman 25cc Gas Line Trimmer
How do i change the pull coard on a craftsman 32cc grass trimmer
    President:
  • Craftsman Master
  • 1,545 Answers
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers
Posted on Oct 12, 2010
How do you change a craftsman 32cc weedwacker gas filter in the gas tank?
Hi davemac918...
I used a long pair of tweesers to grab the filter, but you can also grab it with a piece of wire with a hook bent on the end of it large enough to fit the tubing the filter is inserted into.
Hook the filter tubing, and pull the filter to the top of the tank and manuver it out of the tank.
Please take time to rate me
Sep 11, 2011 | Craftsman Convertible 25cc. Gas Line...
Craftsman 32cc gas trimmer ran a couple times this season, then will not start. Changed plug, new gas mix, cleaned filter and spark arrestor. No luck. Pull cord is hard to pull in the first foot or so,...
Pull the spark plug and hold the side against the engine while pulling the string. check to see if there is a spark you may need another person to help. Was the air filter oily when you cleaned it? If so you might need to remove and clean the carburetor.
Jun 07, 2011 | Craftsman Garden
Starter rope pulled out and wont retract on craftsman trimmer/edger 32cc convertible incredi-pull
remove the starter cover and try to wind the starter rope manuly. the rope may have to be replaced if worn or broke..
Oct 22, 2009 | Craftsman Garden
How to add more line in my craftsman 32cc
Invert the trimmer pull the center of the head straight off. Wind new line in counter Clockwise direction. There should be a hole or notch to place the center of the string in. insert each end of the sting through one of the holes in the head and reinsert the spool into the proper position. Be sure that the automatic advance is movable by pressing down and pulling out more string. Cut string to proper length and restart your trimmer
Jun 06, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc Line Trimmer pull start will not engage engine.
Hi I have a craftsman 4 cycle model no. 316.791970 gas trimmer. When I pull on the rode there is little resistance . I took the sparkplug out and put a flash light down the hole and there is a thing that is moving . What should I look next, or do you know what is wrong? Thanks for any help! I've had it only 3 years and already Sears have replace the clutch assy.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
May 04, 2009 | Craftsman Garden
Craftsman 25cc Gas Line Trimmer Logo
369 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
