Question about Denon AVR588 Receiver
Bass ant Treble adjustment
With tone defeat off. How do I adjust my bass and treble manually? On the unit and from the remote control?
  • spartanlich1 Jun 02, 2008
    Sound has too much treble/midrange. I see no way to adjust it besides presets. Jazz club..etc. I made sure the speaker set up is correct. Subwoofer is off.
4 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: adjusting bass and treble
You can download manual here and see what it can do without remote.
http://audio.manualsonline.com/manuals/mfg/panasonic/panasonic_sa_saxr25.html
Posted on Nov 10, 2009
dunnbiker
  • 8546 Answers
SOURCE: My Denon AVR-1802 is permanently stuck in tone defeat
Is this only when using external inputs? The manual says the Tone Control will not function in Direct Mode. Try Stereo and various DSP surround modes to see if the Tone Control works.
Posted on Apr 21, 2009
smarthome2
  • 1114 Answers
SOURCE: How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
Posted on Jul 01, 2009
adamncc1701
  • 158 Answers
SOURCE: lost my remote how to
Hello,i hate to be the bearer of bad news but to change almost everything on that model you need the remote,including channel levels ,bass and treble etc...
Posted on Feb 11, 2011
I have Kenwood 106vr receiver, still working but lost remote control. Is there other way to adjust the BASS & TREBLE directly in the unit?
Hello
Not possible to adjust the tone without the remote.
if you have the possibility for a universal remote like "Logitech" remotes its Recommended for such cases, that will be easier for you to control the the AVR system.
Jun 13, 2016 | Kenwood Audio Players & Recorders
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
Zone 2
I would consult your owner's manual but I don't think you can adjust the bass/treble levels on the zone 2 outputs.
May 21, 2013 | Denon DRA-397
I have set up a BOSE Accustimass System with my STR de485 receiver. How do I adjust the treble/bass?
hi,
if u are using bose speaker system then remember one thing. go to speaker setup and select all the speakers as large not small. then only u will get a good tone. bose speakers will handle the output power of ur amplifier.
u can only adjust the bass and treble of ur frond Channel speakers. for that
select multi channel surround sound and the increase and decrease the bass and treble
ok
Dec 31, 2010 | Sony STR-DE485 Receiver
Jun 30, 2009 | Yamaha RX-V657 Receiver
My Denon AVR-1802 is permanently stuck in tone defeat. The display actually shows that the tone defeat can be turned off and on, but the tone controls, ie. bass and treble do not alter the sound in any...
Apr 21, 2009 | Denon AVR-1802 Receiver
DENON 2308
IF YOU HAVE A MANUAL FOR YOUR DENON THE INSTRUCTIONS FOR ADJUSTING THE BASS AND TREBLE IS ON PAGE 40 UNDER TONE CONTROL IF NO MANUAL FOLLOW THIS LINK TO DENONS WEBSITE http://www.usa.denon.com/AVR-2308CI-OM-E_109.pdf
Nov 26, 2008 | Denon AVR-2307 Receiver
Reciver need to adjust bass or trebel
Hi Brent
hhmmmm, I searched through the manual to find this info for you. It appears that the tone adjustments are initiated by the "tone" button on the REMOTE. I could not find any reference to there being a button to do same on the front of the unit. Odd, but there you go.
  1. Use the tone key(on remote) to get "tone" up on the front of the unit.
  2. Then using the multi up-down keys, turn the "tone on".
  3. Once you have got to here, use the tone key to select "bass" or " treble"
  4. Using the multi up down keys, adjust the tone controls to your liking with the multi up down keys
you can download the manual from
http://www.retrevo.com/s/Kenwood-VR-60RS-Receivers-review-manual/id/480bh239/t/1-2/
Just enter your email address and away you go. Good Luck. A "FixYa" rating would be great for my time to research this for you.
regards
Graeme
Feb 16, 2008 | Audio Players & Recorders
Treble and bass function
In looking through the service manual for this model, I see a Tone Switch that allows you to bypass the tone circuits, and it may be the one all the way to the left of your front panel. If that's not it, I would get out the owners manual and see what they suggest. I doubt that you actually have an electronic malfunction with your unit.
Jan 18, 2007 | Onkyo TX-SR503 Receiver
Denon AVR588 Receiver Logo
215 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
