Question about Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ...
I have a leak at the water connection using the connector T that comes with the set. The leak appear to be coming from the top water line? The side spray line I pulled it out snadpaper the copper line and pushed it back in place. Is ther another way of connecting the water lines if the connector is bad?
  • 4,350 Answers
You may have a torn or damaged o ring. Pretty much you need to get a replacement hose from Price Pfister.
Posted on Oct 11, 2010
  • 1 more comment
  • dennis169 Oct 11, 2010
    The leak is at the T connection that a press fit connection.
  • Mike Oct 11, 2010
    Yes, and that T is part of the hose, correct? I do not recall any press fit, but rather a fitting that press on, and is retained by a clip of some kind. Inside of the T fitting is an o ring. Doubt that you would find the correct o ring. You may need to pull the faucet to clearly inspect the area. If the metal is damaged or deteriorated, you will need to replace the faucet, which may be under lifetime warranty. IF metal is okay, I am back at replace the hose that has the t connector, Install at an angle and you can tear the o ring....Hope this helps.
    Yes you are probably right, the fitting looks like a air hose connector. You press it in as hard or far as you can the pull it back so it locks in. I didn't think it would have an o ring in but I'll try to look, I just hate to take it all out after I just installed a new sink. Thanks again
Water leaking into the bottom of refrigerator
Hello - There are a few reason for this issue to occur, for example the refrigerator could have a crack in the defrost pan, a defrost drain line blockage, or a leak from the water supply line for the dispenser or ice maker (if you have a side-by-side refrigerator). Try confirming that the vales are tightened. If the connection is still leaking, turn of the water supply line to the water valve and take the connection apart. You can try using Teflon tape when retightening the connection to ensure a good seal. If these suggestions prove to be ineffective contact a professional to move forward accurately.
Nov 25, 2012 | Frigidaire FRT17G4B Top Freezer...
2000 mazda protege water leak under passenger side. A/C not used. Can't see any water in engine compartment or on firewall. Floor carpet is dry. Just drips from big bolts on frame under pass. side.
Possible the hot water line to the heater that has leaked from the water jacket or the connection at the heater pipe. You must be able to use a good observation lamp to look into this section so that the joint from where the leaks appears is located. Possible that the gland or the connector can be tightened to stop the leak.
Sep 19, 2011 | 2003 Mazda Protege
Water is not coming out of the dispenser and ice maker is not working.I just replaced the water filter with a new one, and nothing seems to be working?
HI. This will be a water inlet valve issue. The procedure below will guide you through the necessary inspection needed to confirm the damage.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Dec 13, 2009 | Kenmore 57029 Side by Side Refrigerator
Whirlpool sideby side fridge - water dispenser and
HI. In most cases, this will be the result of a failed inlet valve. There are some other causes, as well. I would suggest to inspect the water lines for freeze over, and obstructions, as well. Normally, the inside lines will freeze over, thus, producing ice within the lines, this will obstruct the flow. Another issue will be the filter. Once this device reaches its filtering limit, it will shut down, thus, preventing the flow to the dispenser/ice-maker assembly. Once you have ruled out these more common issues, Move on to the procedure below for the inlet inspection.
Dec 08, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Got a problem with my SmartWater filter. the water stopped, I then replaced with a new filter. but there is no water neither. and also there is water leaking out when the filter was taken down.
HI. There may be some issues here with the actual inlet assembly. it must be inspected thoroughly. Follow the procedure below to assist with this issue.
Dec 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have an Amana side by side model SRD20S4E. The ice maker has stopped working. It appears the water is not coming into the ice maker. Would it be the valve? Not sure how to test to see if the water is...
Hi. The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink, but normally behind the unit). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
Nov 21, 2009 | Amana SXD524VW Side by Side Refrigerator
The water doesn't come out of the fridgerator
HI. Check your water filters date on the capsule. If it is more than 10 months old, this will be the culprit. If the water filter is not more than 10 months old, i would then advise to test the operational value of the inlet assembly.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Oct 15, 2009 | LG LRSC-26922 Side by Side Refrigerator
Water not dispensing in side by side Whirlpool refrigerator
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source. Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced. Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Jul 22, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice works but no water comes out. when you press the water dispencer the waterleakes on the floor. I've been told I have a broken bladder, but I don't know where to locate it? Nor how to replace it.
Remove the toe kick, on the t side you will see a connector where two water lines meet, if the water is leaking there, push the two lines into the connector and then pull back on them to make sure they are sealed. test to see if it still leaks, if it does push the red or blue ring around the line in, while doing that pull the line out of the connector, repaet for the opposite side. use a razor or sharp knife and cut about a half inch off each line, make sure they are flat, push them back into the connector, and pull to seal, if it still leaks replace the connector. If the wateer is coming out of the freezer door replace the water line that goes through the door.
Jul 07, 2008 | Frigidaire FRS26R4A Side by Side...
Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
754 people viewed this question
Top Price Pfister Plumbing Experts
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
