Question about Whirlpool LER4634J Electric Dryer
No power. Does drier have fuse inside? - Whirlpool LER4634J Electric Dryer
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 17, 2010
Miele washer does not power on at all
check the door switch or the mains fuse. they are both on the inside.
Feb 15, 2016 | Miele WT 2780 Front Load Washer
Why my Whrilpool Drier AWZ 555 is not drying the clothes and power light is blinking?
Check to make sure it's getting full 240vac power. Some or most driers are fed from two breakers in the box. If one is tripped you aren't getting enough power. That could be causing the blinking light. Also check for enough exhaust flow to prevent overheating.
May 18, 2014 | Whirlpool Dryers
I have an admiral electric dryer. It stopped in the middle of a cycle and the light is out and it won't turn on. I checked the fuse box, the plug and the belt is still on, so what do I do now?
Did you test the power outlet with another device...Sometimes a power outlet will fail under the load of a high current appliance like a drier...If the drier runs on 220 volt current...and have circuit breakers instead of fuses...make sure the 220 volt breaker for the dryer is not tripped...If it is tripped...reset it....if not...have a tech to check the outlet. oncee it is established that the drier is getting power and still not working...you may want to get it checked out by service personnel....Hope this was helpful....PEACE.....
Jan 25, 2012 | Admiral Dryers
My Zanussi dryer TD 901 EC was on along with the washing machine. The fuse box stopped the electrical current on both. When I reconnected the electrical circuit the washing machine went back on but my...
Hi Patricia. Of course it is hae=rd to be sure from a distance, but the electricity supply (fuse box) turned off either because of an over current spike...or a short circuit. I would think it is possibly a short in the Zanussi which may have shut the fuse off and possibly at the same time burned out a live wire inside the machine. My advice...disconnect from power and call a repairman. Hope this helps.
Apr 22, 2017 | Zanussi Dryers
My Roper dryer RED4400VQ won't start
Have you checked the door switch? If not make sure it clicks as it should. Next confirm that you have full power to drier, sometimes they have two 120 breakers in your breaker panel, make sure one has not tripped. Also check drier cord and receptical. If all is well it is probably the thermal control fuse behind the back panel on drier, on the blower houseing. It is a small white narrow fuse with two wires to it. There is no way to reset this, you will have to purchase another around 15.00. just be sure to turn drier off and unplug before removeing panel. Good Luck
Dec 23, 2010 | Roper Dryers
Electric drier takes 2 to 3 cycles to dry one normal size load
Have you tried cleaning the actual inside of the drier?
When you use drier sheets the wax on the sheets melts onto your clothes and makes them soft, but the wax often gets stuck in the holes of the drier making it incapable of drying the clothes in one load. Try scrubbing the inside of your drier with some hot water.
Apr 13, 2009 | Roper REX3614KW Electric Dryer
Roper Drier no heat and continuous run for two hours
Your drier heating elements operates on 220 voltage, the drum and clock operate on 110, so you either have a blown fuse in one side of the fuse box ( easy fix )some time the circuit breaker will just need to be reset by turning it off and back on, or your heating elemant has opened up and will be more expences to fix, or it could just be a wire end has burned off. unplug plug from outlet remove back from drier and have a look see, and if bychance you have forgotten to clean your link trap if could be a high temp safety that has open and sometimes can be reset by pushing the reset button, all this is inside the back of the drier, if after that it may be time to call your friendly repair shop
Oct 20, 2008 | Roper REX4634KQ Electric Dryer
Ge Electric drier not working
water indicates vent issue as far as not starting there is a thermal fuse mounted to element housing it may be out also be sure door is fitting and shutting ok
Jul 23, 2008 | Dryers
Drier wont start
yes there is a thermo fuse in the dryer eather on the element houseing are on the inside back by the houseing
Mar 06, 2008 | GE DBXR463EBWW Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
