I have rxsbhp0909 headphones,i dont have the pairing code for them,plz help
How do I pair my phone and iPod at the same time?
I don't think you can pair two devices at the same time. You will have to pair one at a time . On the phone go to connections and bluetooth , switch bluetooth on and make sure it is visible. Press scan for devices .your headphones should be shown in list if they are set to visable .press pair and a option to put in a 4 digit code willcome up type in a code and put same code in the headphones and press pair these devices. Do the same with the ipod but type in a different code and put code for ipod in headphones pair devices . You should be able to listen to either one
Jan 21, 2015 | Cell Phones
Headphone is added to PC (hp NOTEBOOK) BUT pc IS ASKING FOR PAIRING CODE ,what is the pairing code ?
Pairing code is the Bluetooth code that has to be shared between the devices you want to connect
often it is 0000 or 1234 (i think you will find the code in the manual of the device you are trying to connect)
May 11, 2011 | Computers & Internet
Backbeat 903 headphones won't pair with Windows 7 64-bit laptop
I had the same problem as you although I was able to find a solution. If your bluetooth adapter on your computer doesn't support A2DP then you can purchase this adapter from IO Gear: http://www.iogear.com/product/GBU421/ or another adapter that supports this feature. Windows will try to install it as a generic bluetooth adapter (which wont allow you to pair the headset) but if you install the disk that comes with this, it will also install the additional drivers needed for the headset.
Walmart carries it for $20 at most stores or $13 online. I got mine at the store.
http://www.walmart.com/ip/IoGear-Bluetooth-2.0-USB-Micro-Adapter/10299060
If you need help installing it let me know I can provide the steps I did.
TJB
Jan 28, 2010 | Altec Lansing BackBeat Plus Mobile ...
When i plug my headphone in my computer to listen to music it works however if the wire turns the slightest bit i lose the sound can u help me out plz
sounds like a loose wire from maybe trying to overextend the allowable distance (cord stretching). alot of times its easier to buy a new pair instead of fixxing. Take the old pair apart if your interested in where the break is. could be easy as a little sawder gun fix.
Nov 07, 2009 | Sony MDR-V150 Professional Headphones
Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
Aug 19, 2009 | TDK Audio Players & Recorders
Pairing bluetooth headphone and mp3 player
search for devices option and visibility!! plz rate this post
Aug 20, 2008 | Insignia Sport MP3 Player
I can only get sound out of one headphone no matter what how many pairs i try with my Philips mp3 player
HI ME AS THE PHILIPS GO GEAR USER MYSELF USING THE 1GB MP3 PLAYER BUT I LOST MY HEADPHONE PLZ SUGGEST ME HOW CAN I PURCHASE A NEW ORIGNAL PHILIPS HEADPHONE .AS I LIVE IN REMOTE AREA PLZ TELL ME THE ONLINE LINK TO PURCHASE THE PRODUCT
Apr 30, 2008 | Philips Audio Players & Recorders
Pin code
Is this the first time you are pairing two Bletooth devices ? Is the security pin for your Samsung phone '0000' ? Usually, the code you have to enter on your phone to pair it with a Bluetooth headset or headphones is '0000' (the number 'zero' 4 times), unless Jensen's Bluetooth headphones use a different pin.
Hope this helps.
zeceten@yahoo.com
Dec 22, 2007 | Audiovox WBT212 Headphones
Computers & Internet Logo
David Payne
David Payne
