Question about Dewalt DW744S 10" Portable Table Saw with Stand
My dc825ka dewalt impact drive will turn forward and reverse but will not impact drive a screw in or out. Why?
  • 30 Answers
Sounds like a problem in the Mechanism assembly. You have the option to attempt to fix it yourself or contact DeWalt and take it to a Local Service Center, you can find your local service branch at www.dewaltservicenet.com. From this website you can also order parts. Here is an exploded view and parts list of your tool. http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=70578&typeId=16779&documentId=36008
Hope this information is helpful to you, if so, please rate me. Thank you.
Posted on Oct 11, 2010
DeWalt 20 V impact. Driver ejects occasionally. Locks in correctly to start then after limited use, bit holder falls out.
These are known for the spring in the nose (#12) to fail.
Using an o-ring pick or small screwdriver remove the hog ring on the end of the bit holder (#17).
Slide the washer, spring, and sleeve off (Be careful not to lose the small lock ball)
The spring that pushes the lock ball forward (#12) is usually the culprit.
Reassemble in reverse order DeWALT DCF886D2 20V Impact Driver Parts
Dec 06, 2016 | Dewalt Drills
My impact driver when in reverse works fine but when in forward it will work for a few seconds then stop and keeps doing that. why?
I'd be looking for a defective forward/reverse switch, or a bad connection/wire on the forward side between the switch and the motor.
Jul 01, 2015 | Dewalt DW056 18V Heavy Duty 18V Cordless...
Want to change keyless chuck
If your wanting the sleeve, #12 on breakdown, then search the part # as There are other places that still have it. http://www.ereplacementparts.com/dewalt-dw056-type-18v-cordless-impact-driver-parts-c-1009_9591_2845.html
Nov 22, 2013 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt dc825 does not run
Look online from there site.Need new one.
Aug 12, 2012 | Dewalt 18v Cordless Impact Screw Driver...
Drill turned on and off intermittently when
Sounds like the switch---might try spraying electrical contact cleaner into it using the small tube attachment.
Feb 18, 2010 | Black & Decker DC825KA 18V Impact Driver
My drill is stuck in reverse
Use left hand screws.....or take housing apart to see what has jamed the selector switch.
Jul 28, 2009 | Dewalt DW056 18 Volt Cordless Impact...
My impact driver wont go in forward or reverse what could be prob
Sounds like the problem is the trigger, or the motor. If you have a continuity meter you can check to see which one will not work. Other wise you will need to try to swap out the trigger and the motor one at a time. Generally if it is one or the other, the cost of the repair is justifiable.
Mar 29, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt dw056 motor working but no drive.
make sure the selector switch is in full rev or full forward and not in mid throw goose the trigger and turn the selector at the same time
Dec 16, 2008 | Dewalt DW056K-2 18V Impact Driver
My chuck is stuck
Your chuck is held onto the motor shaft by a screw located inside the chuck. This screw has loosened and requires tightening. This screw has reverse threads and in order to tighten it, you need to turn the screw in the opposite direction or in oither words, in the reverse direction.
Jul 08, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt DW744S 10" Portable Table Saw with Stand Logo
32 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
