Question about Sport & Outdoor - Others
I need the screw size for a marksman repeater
  • 3 Answers
Oct,11/10,, First you need to know it the item is European or Japanese which all use Metric threads. If it is USA it probably uses Imperial threads which are fine or course. England (British) also have fine and course but not interchangable because thread angles are different. Anything of Japan older than 1967 also uses Metric but not the same metric as 1968 and newer. In 1967 there was a world conferance that was "ISO" international standard organization. Some Metric stayed the same but in small sizes under 6 MM, the 5s, 4s, and 3 were changed and all these have a tiny raised or indented dot to tell you they are the new thread. Some motorcycle parts use special not common threads to prevent you from using a cheap poor qualiy nuts or bolts that might fail when in use ( steering parts or brake parts on a car). Occasionally you might use too long of a bolt or screw and it may extend and break something else. Before 1901 most mechanice were called FITTERS because there was not many standard parts and everything had to be fitted. Henry Ford helped make things interchangable so we call them standard parts. If you could give some rough dimentions of the screw ( 3/16" long by 1/8"...or 5 mm by 13 mm long,,, or other American sizes are size 6X32 or 8x32 and different lengths. This would help. Can you find some old fellow that lives on a farm and he might be a mechanic and can figure what you need. Good luck, EEL
Posted on Oct 11, 2010
I need order a part for my Marksman repeater,how can I do ?
why notify contact the company that makes it and find out who their distributors are??
Jul 08, 2017 | Measuring Tools & Sensors
Is my Marksman Repeater a pellet & BB gun
yes it takes .177 BB's which is also the size of pellets, plus darts and bolts.
Sep 07, 2015 | Optics
How do I load the ****** Marksman 177 cal repeater
hold in right hand, depress cocking release with thumb, pull back cocking slide (takes some effort) till it locks out, push in on the lower front of barrel to rotate loading port to the up position (this won't move unless the cocking slide is pulled back), load BB in the top hole that is exposed (or a pellet in the lower hole), push loading port back down flush with barrel, push cocking slide forward. Marksman is now loaded. push safety button in so it is engaged. When in an appropriate place to shoot a target, push safety button back with your right finger (safety is off) and squeeze trigger.
Oct 17, 2014 | Optics
Parts schematic marksman repeater pistol
http://www.pyramydair.com/manual/marksman-1010
This is easy to disassemble but take careful notes/ pictures as you go because the springs have to be in the right places.
Oct 21, 2013 | Sport & Outdoor - Others
How to put in co2 cartrige in a.177 cal 4.5mm
Hi wendyavery...
The Marksman 2000K does not use CO2 cartridges, it uses a spring to act as the "power plant"
Go to the following webpage and check it out
Please rate me
Bud
http://www.pyramydair.com/s/m/Marksman_2000K_Air_Pistol/644
Oct 06, 2012 | Marksman 2000K Air Pistol - 0.177 Caliber...
How do you load BB's in Marksman repeater 177 cal pistol (hand gun)
1) If you have sucessfully released the safety lever, grab the textured black grip of the cocking mechanism and pull it back until it locks into place.
2) In a safe manner, hold the pistol by the handle with your left hand and carefully grab the black plastic sighting mechanism at the end of the barrel with your right hand and pul this black tip end of the pistol downward. You should find that the other end (which lies more mid-barrel) will pivot upwards, giving you access to the loading tube.
Feb 03, 2010 | Marksman X7 Extreme 3-Channel Remote Start...
Marksman 1010C repeater air pistol
sorry if you already learned but you have to **** it, and at the front under the barrel exit is a button looking shape press down on that really hard and on the top of the gun a sloped shape should appear. do not put the bb in the circle shape hole put the bbs in the top square shaped hole. push the object down and aim then pull the trigger!
Sep 08, 2008 | Sport & Outdoor - Others
Sport & Outdoor - Others Logo
65 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
