Question about Cameras
The battery is charging but when i put the battery back in the camera it wont turn on
  • 3,083 Answers
Most of these type of problems are either power related, or due to a "stuck" lens. First thing to check is whether the battery is actually charged (measure it with a voltmeter). Also, make sure the battery contacts both on the batteries and inside the camera are clean (you can use a qtip and at least 90% isopropyl alcohol.
Here's a couple of sites that list things you can try to get it working:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
and
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Try their suggestions- they say about 50% of the cameras can be fixed trying their suggestions.
If the camera still won't turn on, it will have to be taken apart and troubleshot. Get an estimate before you have it repaired, since it can be costly, and justify going ahead and buying a new one.
Good luck, and hope this helps.
Posted on Oct 11, 2010
Camera does not turn on
Rosa, I think the only thing you did was get out the batteries and tried to charge them and then jut put them back in the camera.
Only a few things could have gone wrong.
One or more cells could have died, during charging. It can happen, special with batteries that have a uneven use. Like once or twice a year the camera comes out the box and then the batteries are charged. Even when you don't use he camera, make it a habit to charge the batteries every few months.
Then it could be your batteries are still in good shape and fully charged, but you put in one or more calls the wrong way around.
Please check carefully if all the cells are inserted correct.
If nothing works, and you can't check the voltage of your batteries, try another set of batteries.
Dec 30, 2013 | GE Cameras
My fujifilm JX500 wont charge
Had the same problem, took the camera back to the shop. Was mortified when the assistant opened the battery slot, took the battery out, turned it round and put it back in again. And it worked. Make sure the battery isn't the wrong way round (only camera I've ever had where it was even POSSIBLE to put the battery in the wrong way round). Orange label on the battery needs to be next to the orange 'release lever' on the slot.
Nov 29, 2012 | Cameras
7 days ago i took my battery off to charge my camera and its fully chrged i put it back onto the camera and it just wont start up. I bought another battery and fully charged it aso and it wont turn on!...
Please make sure that the battery is clean and also the terminals within are clean. If you had been using the camera prior to the charging then the camera must work unless if the battery was spoiled by wrong charging. If you can use a multimeter to check the voltage which must be as specified on the battery label. Now make sure that the battery gets good contacts into the camera when inserted. If this wont work then it possible that there are errors within the camera and you need help from the nearest Nikon center.click the link below
http://www.nikonusa.com/Service-And-Support/Product-Support.page
Mar 28, 2011 | Nikon D3000 Digital Camera
My camera, a nikon d70s, wont turn on and work. ive taken the battery out and out it back in, still wont work. i then tried 2 charge the battery but still wont work. i then tried to re-set it but it still...
If the camera does respond when you hold down the shutter release, then the internal clock battery may have drained. As the manual says on page 17, charge your main battery, put it in the camera, and leave it be for up to three days.
Feb 15, 2011 | Nikon D70s Digital Camera
XT not turning on
I was taking pics with my rebel EOS and it turned off. I charged and changed the battery but wont come on
Sep 18, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Camera Won't Charge
my finepixz3 got wet. but after a few days it worked! but when the battery ran out it wont charge. is it the battery? it turned on a few sec when its in the cradle but it wont last after a few seconds it would turned off. is it the battery or the camera itself?
Sep 01, 2008 | Fuji FinePix Z3 Digital Camera
Olympus Stylus 770SW Battery Problem
It may be the battery - try using one of your spare batteries, see if that makes a difference.
Jul 10, 2017 | Olympus Cameras
Camera wont turn on.
Main power led to on/off switch is crushed and not enough power gets through.
you have disassemble the camera.
I would think first before tring this.
Remove 3 screws on bottom, 1 in battery compartment, and 1 at very top of usb flap (look good).
Now slide the side piece starting at the usb flap then apply pressure to top and away from unit.
now look for 1 silver and three black screws (facing back and front, look good).
See the big red wire leading to main on off switch if it crushed thats the problem.
I replaced it with a longer piece of wire.
Remember to replace battery door first if it fell off during process.
*TEST NOTE: You can place batteries in and place a penny across the bottom to test before you put it back together.
Oct 31, 2007 | HP Photosmart M425 Digital Camera
Camera just wont turn on...help please
I opened up mine today and found out that all you needed to do was put the plastic gear back into place and it's A ok. Open up the camera and when you're facing the front, check the little plastic compartment on the top right to see if the gears are in place. I fixed it and everything is A ok now. :)
Nov 19, 2006 | Casio Exilim EX-S600 Digital Camera
Cameras Logo
35 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
