Question about RTO Siemens High-power Touching Digital Bte Hearing Aid
How does siemens high-power lotus 13p digitalble hearing works
Siemens lotus hearing aid emits constant tone
Is the (acoustic) tube obstructed or partially blocked ? If the problem is inside the hard plastic flesh-coloured opaque part, you will need to take it a technician, return it to the manufacturer, or replace it. There are no user-serviceable parts inside.
Jan 14, 2014 | Select Products Hearing...
How to set volume on Siemens Lotus 23 P
You may be able to adjust the sensitivity of the device iusing the small, partially recessed wheel on the back of the unit - in fact this is the largest of the controls !
Otherwise you need to take the unt and yourself to an audio technician for adjustment
Apr 16, 2013 | Select Products Hearing...
Show adjustments on touching hearing aid
Can you give a hair cut by phone ?Just turn the dial .
Dec 09, 2011 | RTO Siemens High-power Touching Digital...
Is this a good product Siemens Super-Power LOTUS 13SP Digital BTE
Blueboy792,
If you havent gotten an answer since posting this question, let me just say that I have fit many Siemens Products over the years with great success. Their instruments are reliable and the company stands behind the product.
The hearing instrument you mentioned may or may not be the product for you depending on your hearing loss and your day to day hearing needs. You and your dispenser must determine this.
Hearing aids are generally adjustable and if you are not having the success you expected you must return to your dispenser for an adjustments.
I hope this info will benefit you. If you have specific problems with your fit please let us try to be of service. Thanks for contacting FixYa.com
Jul 18, 2009 | Select Products Siemens Super-power Lotus...
RTO Siemens High-power Touching Digital Bte Hearing Aid Logo
240 people viewed this question
Top RTO Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
