Question about Seagate Barracuda 7200.7 200 GB Hard Drive
My Barracuda 7200.7 200GB drive failed. The computer does not recognize that the drive is attached. I can hear it power up but then nothing. No clicking or other noise indicating that the heads are moving. Model: ST3200822AS, Firmware 3.01. Any ideas and what to do next?
    Guru:
  • 124 Answers
Try connecting it to another sata port on ypu motherboard or try using another sata cable. If still same problem go to the BIOS if that drive is detected properly. You should see there the model number and the capacity, if its not there then the hard drive has a problem, have it replaced.
Posted on Oct 11, 2010
Seagate 160gb hard drive recognized in device manaager but not my computer why
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this helps you
Aug 24, 2011 | Barracuda Networks Seagate ST3160215A...
I have a seagate barracuda 7200.12, 500 GB, HDD, as suddenly it is not working nothing is showing up, some type of clicking sound is also coming from it. the computer detects the hdd, but nothing is...
If you have another computer, you could try to plug it in there as a slave/secondary drive so that you can try to see if My Computer would still recognize it. If it works, then great, you can still do backups. If not, and you really need that data, you might want to get the services of a data recovery company.
Jul 29, 2011 | Seagate Barracuda 7200.10 500 GB SATA Hard...
My internal harddisk locked when boot Seagate Barracuda 7200.7 ATA 40 GB
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 16, 2011 | Seagate Barracuda 7200.7 40 GB Hard Drive
I can't find driver for my Barracuda 7200.7 80GB
control panel administrive tools ,computer management ,device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/s
to do this right click on the ? x ! select reinstall driver
if your computer came with a motherboard disk the drivers could be on it
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 09, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Hello sir,please help me to solve my problem. i have a seagate barracuda 7200rpm which storage capacity is 320 gb and which have a problem.when i am trying to start my pc it shows boot error,please select...
A bad/faulty lead can lead to a computer not recognizing a hard drive and any other connected devices
One bad lead can cause a computer lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to your hard drive
hope this helps
Nov 14, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My seagate barracuda 7200 80 gb having s/n: 9qz0c2zz is not recognize by my computer im using windows xp operating system
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Sep 06, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Twin drives in an external HDD, and it quit, but I can hear them working. The fan also quit too.
http://atulchitnis.net/files/seagate.pdf http://www.seagate.com/staticfiles/support/downloads/firmware
May 20, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
SECOND HARD DRIVE NOT RECOGNIZED
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Nov 11, 2008 | Seagate 250GB Barracuda 7200.10 ATA-100...
Seagate Barracuda 7200.7 200 GB Hard Drive Logo
230 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
