Question about Sentry Fireproof Safe
I locked myself out of my sentry safe SB0500. Can you tell me what the factory code is? BD582786* I can not find my paperwork and I never changed the factory code that came with the safe. I have important papers that I need to get to as soon as possible. Can you please help me? Thank you Karen
dmathwizard
  • 113 Answers
SOURCE: Lost key to sentry safe
You have to contact Sentry directly to get another key
Sentry Safe
1-800-828-1438
www.sentrysafe.com
Posted on Mar 05, 2008
SOURCE: sentry safe msw3517
I have a Sentry Safe MSW3517 and forgot my code.
Posted on Nov 19, 2008
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
  • 3 Answers
SOURCE: sentry codes v260
Call SentrySafe @ 1-800-828-1438. They may require you to send a notarized letter to their Linden Ave site in Rochester NY
Posted on Aug 24, 2009
SOURCE: Sentry Fireproof Safe #1100 Lost Key
no if you turn your lock box around so your key is facing away from you and place your right hand on the side top and your left hand on the box and push the lid to the right a good inch and a half and lift the box will open no problem key or no key. this is a very poorly made safe
Posted on Oct 03, 2010
I have lost the combination for my safe model V330 my model number V330 Sentry safe
  • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Retype the user code to verify it is working, and then close the safe.
Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
Need factory combination for a Sentry safe A5781
Call 1-800-828-1438 with the serial number of the safe.
Dec 25, 2014 | Sentry Fireproof Safe
I do not remember the factory code for my sentry safe sb0500 and need to change the cold
All you have to do is find your owners manual the sentry safe combination was posted in. Unless you locked it the safe as happens all the time. After all that is the safest place for it right. Or you can just call a locksmith service tech
Feb 18, 2013 | Sentry Fireproof Safe
How can i open sentry safe,i lost paperwork and can't remember code
Dec 07, 2012 | Sentry Fireproof Safe
How do I open a sentry s3877 safe when the battery is dead and safe is closed
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Sep 23, 2012 | Sentry Fireproof Safe
Lost factory code for sentry safe model #d8W5840
did you ever find the factory code? I lost mine also. if you have the factory code for this model please message me on facebook.com/vernhartjr
Sep 09, 2012 | Sentry Safe Sentry Fire-Safe Combination...
Lost factory code
hi.
the factory code for sentry safes would normally be 00000.
if this does not work you may have to contact Sentry with the safe model and serial number .
these are normally found on a label on the back of the safe, or a label on the front edge of the safe.
contact details for sentry can be found on www.sentrysafe.co.uk
hope this helps
Mar 26, 2011 | Sentry Security Safe with Electronic Lock...
Lost codes
would you know the factory recovery code for sentry 1610 as
i lost it or it is locked in my safe. My battery has been dead
for some time and I think it lost it's memory.
Jul 17, 2009 | Sentry Fireproof Safe
Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Mar 22, 2009 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
298 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
