Question about Whirlpool Microwave Ovens
I have a Whirlpool microwave model # WMH1162XVQ-2 this is the 2nd one I have bought within 2 yrs the last one being on 8-29-09 and now this one is not working. Everything on it works it turns all the buttons work but it will not heat up at all what can I do? These microwaves are not cheap and a 1yr you should not have trouble with them not working. Still have my reciept on this .
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave won't heat food.
This would be under warranty, so Maytag should take care of it for you: http://maytag.com/support/index.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Kenmore Galaxy Microwave Hood Combo Model 72180002400
Since it sounds louder than before, it is probably a bad high voltage diode or magnetron.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
Sears may send you a magnetron to install yourself since it's under warranty. For that or warranty service, contact Sears at http://www.sears.com.
You can save about $75 by taking it to the shop yourself, as opposed to an in-home service call.
Posted on Aug 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: kenmore galaxy microwave model 721.80002 1500 watts does not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/xformer.html
Posted on Dec 22, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: microwave wont heat
The manual says "while in standby mode, press and hold the '3' key on the keypad for 3 seconds until 2 tones sound and the 'DEMO' icon appears. Repeat to turn demo mode off."
You can download a copy of the manual here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208206572.pdf
Posted on Jan 26, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: have a Whirlpool microwave oven, model MH3185XP. Just stopped wor
In some Whirlpool models, there are more than one fuse, and two or more thermal devices which can interrupt power to the oven.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Please write back with more details if you need further help.
Posted on Mar 02, 2009
Whirlpool gold microwave model gh6208xrs stopped heating
As a service tech do not attempt to service a MW call a professional or replace there are components within that raise voltage from 120VAC to upwards of 5000VDC leave it alone call a pro
Sep 02, 2014 | Whirlpool Microwave Ovens
Where is fuse?
No fuse. Unplug for 1 minute, plug back in. Check breaker, its probably on a dedicated
breaker if the house is built within the last 10 to 15 yrs or so
Dec 18, 2010 | GE JES1246 1100 Watts Microwave Oven
Microwave does not heat if time is less than 1 min 30 seconds
Generally speaking, charcoal filters should be changed and grease filters should be cleaned about every six months, or whenever you notice they are getting dirty & clogged. Yours will likely have one or the other - probably not both - depending on whether it's vented or it recirculates.
A clogged filter will cause the supply of cooling air flow to be lessened, allowing the magnetron to overheat. It only takes one severe overheating to damage or destroy a magnetron.
One common way for a magnetron to fail is that its heating power is less and less, then it just stops heating.
Magnetron's will usually have a warranty of 5-9 years, but you'd still have to pay the installation labor.
You can save a $75-90 home visit by removing the oven form the wall and taking it to a local Whirlpool-authorized warranty servicer.
The date of manufacture will be on the model tag in the unit, and the warranty terms will be in the owner's manual. Many manufacturers will use the serial number and date of manufacture to validate the warranty in lieu of a sales receipt.
You can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts and accessories by entering your full model number here.
Jun 26, 2010 | Whirlpool WMH1162XV Microwave Oven
Whirlpool timemaster microwave removal
What caused the plastic metal rack holders to burn against the metal rack
Apr 06, 2009 | Whirlpool MH7140XF Microwave Oven
Which brand microwave oven is best in the market
That kind of depends what you want. Kenmore, Whirlpool and Fridgidare are the best value. Maytag, Amana, Jenn Aire are a little higher end. LG and Electrolux are the higher end. When it comes down to it most of them have some of the same components. Keep it simple. The more bells and whistles, the more likely it won't last. Sometimes the cheapest ones are the best. Personally, I have a countertop unit by Emerson. 10 yrs old, no problems.
Mar 25, 2009 | Samsung 80092 Microwave Oven
I have a convection/microwave oven that is approximately i yr. old. it recently stopped working. i bought it at walmart for 149.00 it worked just fine and i was so pleased with it so was very surprised...
You can find contact information for Daewoo at http://www.e-daewoo.com/customer_service.asp
If it's within one year, it should still be under warranty.
Either way, I would recommend contacting them for your nearest Daewoo-authorized service center.
Most recent Daewoo owner's manuals can be downloaded here.
Jun 25, 2008 | Daewoo Microwave Ovens
Starting by itself
Time for a service call. Should not turn on by itself at any cause. Circuit board is my guess. May be cheaper/easier to get new microwave. My first one lasted about 15 yrs--and the circuit board (touchpad) died. Bought new microwave oven.
Dec 12, 2005 | Emerson MW8775W Microwave Oven
Microwave Ovens Logo
521 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
