Question about Philips Televison & Video
32PFLL5522D/05 TV is stuck on digital channel 301 with no sound, any advice much appreciated.
  • hilly2008 Oct 11, 2010
    Thank you so much your solution worked.I am not very technical and had not tried the menu button on the side, but it worked and now I will have a happy husband on his return from work. Very many thanks for your help. Hilly.
  • Philips Master
  • 11,800 Answers
I.m starting with the assumption that you have tried to reset the tv (press and hold down the MENU key on the side of the TV set for 5 seconds then configure it again) and that hast worked. In that case the controller is stuck on a loop - hardware fault.
The only thing you can do is to take the tv to an authorised repair center, the mainboard of the tv will have to be replaced and they are the only ones with access to new replacement parts.
Posted on Oct 11, 2010
Philips 42PFL5522D/05
It sounds that the fault is with its main board. It will be best to contact the authorized service center for Philips in this case.
Oct 06, 2013 | Televison & Video
I PURCHASED A SAMSUNG MODEL HLN43W REAR PROJECTION TV FROM CIRCUIT CITY ON 05/22/04 WITH A TWO YEAR PROTECTION PLAN. AFTER 6 MONTHS FROM DATE OF PURCHASE THE CHANNELS STARTED CHANGING ABOUT EVERY SECOND...
the circut board beneath the power /volume/and channel up -down has carbon switches the carbon switches are corrupted and that board needs to be replaced
Apr 02, 2008 | Televison & Video
NEED USER MANUAL FOE DIGITAL PRISM 3.5
HOW TO USED I FALLOW UP BUT I CAN FIND ANY CHANNEL
Jul 24, 2012 | DIGITAL PRISM 3.5" Color Pocket Lcd Tv...
How to get TV audio on the FR300 radio?
Your TV band radio won't work anymore now that the US has switched to digital broadcasting. The frequencies now in use aren't the same now, so the radio can't receive them. Plus, the radio doesn't have the circuitry to decode the digital sound even if it could pick up the broadcasts.
Sad to say, you have a radio that now picks up only AM/FM/weather and static. Also, as far as I know, nobody is yet marketing a radio for TV sound with digital capability. All you can do during a power outage is use a new TV with battery capability and digital tuning.
Mar 02, 2010 | Eton FR300 AM/FM/Weather/TV Radio
I am trying to set up the "favorite channels" function on my harmony 880 remote and I keep getting an error message that the channel numbers are not valid. On my TV, for example, NBC is 05-1 (that's what I...
I have seen channel designations like this when using a satellite TV provider. From what I know (which is not a lot, I'm afraid) is that some affiliates offer analog and digital and digital sub channels so an example would be:
05 (main analog channel)
05-1 'digital' (depending on the receiver)
05-2 'digital sub channel'
05-3 'digital sub channel'
etc
So, you may want to try just putting in the main channel '05' when using the Logitech software to program your favorites. Below is a link to a good post on the Logitech forum that tells how to program your favorites. Hope this helps!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9691
Mar 24, 2009 | Logitech Harmony 880 Universal Remote...
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Apex 32" TV - Blue Screen & Channels keeping running/changing
blue screen indicares that there is a problem in blue cathode circuit. please check 1 blue video output supply. 2 blue video ckt defective 3 signal from chroma ic to blue cathode missing. 4 loose connector 5 crt base loose. 6 chroma ic defective. I think sound will be ok .
Sep 22, 2007 | Apex Digital PF3230 32" TV
RCA F36685 No audio on cable channels
1)Try hard reset = unplug AC cord overnight
2)Further audio circuit work is shop repair by skilled,senior
RCA products technician........................................T.
Sep 03, 2007 | RCA F36685 36" TV
Curtis Mathes CM32010 has no sound
any user manual online ?
unplug from wall
see if remote will get you to system settings audio
Apr 06, 2017 | Curtis-Mathis CM32010 TV
Televison & Video Logo
877 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
