Question about Samsung CLP-510 Laser Printer
I have a low toner message. The copies are coming out with a faded look. What do I need to buy?
    Brigadier General:
  • 10,406 Answers
Remove the toner-cartridge, and gently "roll" it from side-to-side,
to more uniformly distribute the remaining toner.
Do not SHAKE it.
If you still have the problem, remove the toner-cartridge, put it into a plastic bag, and take it to any computer store, such as OFFICE DEPOT. They will often give you a (20%) discount on a replacement cartridge, when you "trade-in" your empty cartridge, and they will dispose of the cartridge in an enviromentally-friendly way.
Posted on Oct 11, 2010
Copies are faded and unreadable when printed or copied at the machine. The toner percentage is showing 25-0% but the machine is not giving a "change toner" message.
Remove the toner cartridge and tap it sharply with one hand whilst holding it with the other. Turn 90 degrees and do it again, repeat until the cartridge is back to being the correct way up.
This will often give you another hundred copies with a cartridge that 'appears' to be empty.
If that doesn't work, you will need to replace the toner,, if that doesn't work, you need a technician or a new machine.
Sep 08, 2015 | Office Equipment & Supplies
The copies from my printer come out faded and washed out but I am not getting any message of low toner. Last night I printed some labels and it has been happening since then.
The print heads may be clogged. Enter the maintenance menu and run the cleaning cycle. If the problem persists you may need to manually clean the nozzles with a Q-Tip and Rubbing Alcohol (Ethyl Alcohol).
Apr 07, 2011 | Brother MFC 7420 All-In-One Laser Printer
What causes a white streak and faded print to appear on copies?
Most often on the PC940 this means your toner cartridge is getting low on toner. To prove this is the cause, just remove the toner cartridge and while keeping it relatively level, shake it side to side a few times. This will re-distribute the remaining toner in the cartridge. Re-install and make a copy. The black streak/faded copy should be much better. If so then I would go ahead and get a new cartridge on the way.
Thank You for using Fixya.
Testimonials are always appreciated!
WheatlandServices
Oct 21, 2010 | Canon PC-940 Black and White Copier
Toshiba e 650 Copier was working and copies were fading so we
When you changed the toner did you remove the strip on the new toner to release the toner
Jun 12, 2009 | Toshiba E-STUDIO 650 Copier
Copier makes faded copies, even though it has toner
the heater unit is the problem.
yo can get a repair kit by search on the Internet or go to Toshiba web site.
the repair kit come with instruction, if you can handle the mechanic part of things. then you are all set.
May 19, 2009 | Toshiba DP5570 Laser Printer
Faded copies
This is usually caused when the toner cartridges are low on toner, or the drum unit needs to be replaced. Try to produce a supplies status page and see what it tells you.
May 07, 2009 | Dell 3100cn Laser Printer
Faded prints about 2" in from the margin
Greetings!
{You used the term "drum". This may indicate a roll type of toner rather than a cartridge style of toner. The following tip is for a cartridge style.}
I get much the same symptom when my HP laser cartridge is running low, and no, it doesn't have a "low toner" indicator either. I get by a little longer with mine, long enough to get out and buy a new one that is, by removing it, holding it over a garbage can at an angle and firmly tapping on it to loosen any compacted toner. I then turn it back horizontally and gently shake it back and forth to evenly distribute the remaining toner through the cartridge and reinsert it into the printer. This usually gets me nice, even prints back and extends the life of the cartridge. I can usually get a few extra weeks out of it by doing this two or three times.
Rob
Jan 14, 2009 | Brother IntelliFAX 4100 Laser Fax
Photo Quality
Check the toner in your printer, It is either low or uneven in the cartridge. Remove the cartridge and gently rock it back and forward. Replace it and check toner levels. You can print a page with this on it fron the menu on the front of the printer.
Oct 16, 2008 | HP Color LaserJet 2600n Printer
Print problem
Have you tried replacing the ink cartridge?
May 01, 2007 | Minolta magicolor 2200 DeskLaser Printer
System Fault
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Jan 29, 2007 | Xerox DocuColor 12 Printer
Samsung CLP-510 Laser Printer Logo
62 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
